Доброго всем. Прошу помощи. Воткнули БП на 12 вместо 7.5. Обнаружил 2 больших вздутых кондера по питанию, заменил. Осталась трабла - модем включается, грузится и перегружается, и так по кругу. В терминале:
CFE version 1.0.37-12.1 for BCM96338 (32bit,SP,BE) Build Date: Mon Jun 9 01:35:26 CST 2008 (root@localhost.localdomain) Copyright (C) 2000-2006 Broadcom Corporation. Boot Address 0xbfc00000 Initializing Arena. Initializing Devices. Parallel flash device: name AM29LV160B, id 0x2249, size 2048KB CPU type 0x29010: 240MHz Total memory: 8388608 bytes (8MB) Total memory used by CFE: 0x80401000 - 0x80528710 (1210128) Initialized Data: 0x8041D740 - 0x8041FF30 (10224) BSS Area: 0x8041FF30 - 0x80426710 (26592) Local Heap: 0x80426710 - 0x80526710 (1048576) Stack Area: 0x80526710 - 0x80528710 (8192) Text (code) segment: 0x80401000 - 0x8041D734 (116532) Boot area (physical): 0x00529000 - 0x00569000 Relocation Factor: I:00000000 - D:00000000 Board IP address : 192.168.1.1:ffffff00 Host IP address : 192.168.1.159 Gateway IP address : Run from flash/host (f/h) : h Default host run file name : 308nfs6358 Default host flash file name : bcm963xx_fs_kernel Boot delay (0-9 seconds) : 1 Board Id (0-14) : 96338E_E7R Number of MAC Addresses (1-32) : 11 Base MAC Address : 00:22:b0:c5:e4:08 PSI Size (1-64) KBytes : 24 *** Press any key to stop auto run (1 seconds) *** Auto run second count down: 0 Booting from only image (0xbfc10000) ... Code Address: 0x80010000, Entry Address: 0x801b0018 Decompression OK! Entry at 0x801b0018 Closing network. Starting program at 0x801b0018 Linux version 2.6.8.1 (zhouyu@localhost.localdomain) (gcc version 3.4.2) #1 Tue Oct 26 22:41:42 CST 2010 Parallel flash device: name AM29LV160B, id 0x2249, size 2048KB 96338E_E7R prom init CPU revision is: 00029010 Determined physical RAM map: memory: 007a0000 @ 00000000 (usable) On node 0 totalpages: 1952 DMA zone: 1952 pages, LIFO batch:1 Normal zone: 0 pages, LIFO batch:1 HighMem zone: 0 pages, LIFO batch:1 Built 1 zonelists Kernel command line: root=31:0 ro noinitrd console=ttyS0,115200 brcm mips: enabling icache and dcache... Primary instruction cache 16kB, physically tagged, 2-way, linesize 16 bytes. Primary data cache 8kB 2-way, linesize 16 bytes. PID hash table entries: 32 (order 5: 256 bytes) Using 120.000 MHz high precision timer. Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory: 5792k/7808k available (1447k kernel code, 1996k reserved, 212k data, 68k init, 0k highmem) KLOB Pool 1 Initialized: 1048576 bytes <0x80600000 ... 0x80700000> Calibrating delay loop... 239.20 BogoMIPS Mount-cache hash table entries: 512 (order: 0, 4096 bytes) Checking for 'wait' instruction... unavailable. NET: Registered protocol family 16 Total Flash size: 2048K with 35 sectors File system address: 0xbfc10100 Blk# BlkOff Blks MemLen Partition Name 0 1408 1 1024 NVRAM 33 40960 1 24576 Config 2 34 32768 1 8192 Scratch PAD 34 40960 1 24576 Config 1 Can't analyze prologue code at 80178774 Initializing Cryptographic API PPP generic driver version 2.4.2 PPP Deflate Compression module registered PPP BSD Compression module registered NET: Registered protocol family 24 Using noop io scheduler bcm963xx_mtd driver v1.0 brcmboard: brcm_board_init entry D%G
Такая же хрень. Заменил все кондеры результат нулевой. Попробую заменить кварцы посмотрим!
