Вобщем необходимо пропатчить прошивку Lucky Star 5S530 на предмет поддержки больших (80Гб) винтов.
BIOS Patcher ver. 4.23. Attention! Advanced qualification is required! Found 1Mbit BIOS! 1. New CPU Support : -> fixed. 2. P3-detect error : is not needed to be fixed. 3. New Koeffs Support : -> fixed. 4. 32Gb-problem : -> fixed. 5. Some HDD detect-problem : -> fixed. 6. "MB"/"GB" string search : -> fixed. 7. 65Gb-problem (1-st step) : -> fixed. 8. 65Gb-problem (2-nd step) : -> fixed. 9. Error display Freq>999MHz : is not needed to be fixed. 10.Error display Koefs>9.5x : not found. 11.New Stepping Support : is not needed to be fixed. 12.Tualatin L2-init error : not found. 13.New Freq in Setup open : not found. 14.Set "Y" as default on exit: -> fixed. Write Allocate addinng: not found. UDMA for "big"-HDD on UDMA33_only_MB fix: not found. Not free space in BIOS! error! if you can`t see all messages - choose 80x50 mode or run with ">report.txt". (c)2002-2003 apple_rom, www.ROM.by
30 EA 5B E0 00 F0 2A 4D 52 42 2A 02 00 00 00 FF FF
Так же не получается и выборочно пропатчить. Всеравно катастрофически мало места
C:\Bios\BP>bp615 5s530.bin /m /s BIOS Patcher ver. 6.00.alpha_15. |for Award/Phoenix & AMI bioses| Attention! Advanced qualification is required! Found 1Mbit Award BIOS! Remove "otkat" (backup key) 1. New CPU Support :for skip this step press "s" or any another key fo r continue...s 2. P3-detect error : is not needed to be fixed. 3. New Koeffs Support :for skip this step press "s" or any another key fo r continue...s 4. 32Gb-problem :for skip this step press "s" or any another key fo -> fixed.... 5. Some HDD detect-problem :for skip this step press "s" or any another key fo -> fixed.... 6. "MB"/"GB" string search :for skip this step press "s" or any another key fo -> fixed.... 7. 65Gb-problem (1-st step) : -> fixed. 8. 65Gb-problem (2-nd step) : -> fixed. 9. Error display Freq>999MHz : is not needed to be fixed. 10.Error display Koefs>9.5x : not found. 11.New Stepping Support : is not needed to be fixed. 12.Tualatin L2-init error : not found. 13.New Freq in Setup open : not found. for skip this step press "s" or any another key for continue...s 14.Set "Y" as default on exit:for skip this step press "s" or any another key fo -> fixed.... Write Allocate addinng: not found. UDMA66/100/133 on UDMA33_only_MB patch: not found. Tweak options addinng: for skip this step press "s" or any another key for continue...s Not free space in BIOS! error! if you can`t see all messages - choose 80x50 mode or run with ">report.txt". (c)2002-2004 apple_rom, www.ROM.by (c)2006 Angel07, www.cgi-scripts.info
Вобщем надо добавить поддержку больших винтов, а как... Подскажите, плиз.
1. cbrom.exe 5s530.bin /epa release
2. cbrom.exe 5s530.bin /vga extract
3. cbrom.exe 5s530.bin /vga release
4. _bp.exe 5s530.bin /m /s
5. cbrom.exe 5s530.bin /vga sis530.vga
6. cbrom.exe 5s530.bin /D
E:\PATCH\5S530>cbrom.exe 5s530.bin /D CBROM V2.07 (C)Award Software 2000 All Rights Reserved. ******** 5s530.bin BIOS component ******** No. Item-Name Original-Size Compressed-Size Original-File-Name =============================================== 0. System BIOS 20000h(128.00K) 1337Eh(76.87K) original.tmp 1. XGROUP CODE 04470h(17.11K) 03089h(12.13K) awardext.rom 2. Other(4E00:0000) 00E6Eh(3.61K) 003BEh(0.94K) modul.tmp 3. Other(2E49:0008) 00020h(0.03K) 00041h(0.06K) start.tmp 4. OEM7 CODE 00000h(0.00K) 00025h(0.04K) tweak.tmp 5. VGA ROM[1] 08000h(32.00K) 045DCh(17.46K) sis530.vga Total compress code space = 1B000h(108.00K) Total compressed code size = 1AE07h(107.51K) Remain compress code space = 001F9h(0.49K)Открытая книга: icbook.com.ua
Чесслово не удержался и заржал! Как все просто!
Спасибо!
Добавлено спустя 1 день 1 час 52 минуты 36 секунд:
Вобщем неплохо получилось. Только штука интересная вышла. Залил я БИОС пропатченный и перезагрузив машину был удивлен. Сначала появляется сообщение видеокарты (ну там стандартно - ГеФорс 4 бла-бла-Мб). А вот после по экрану бегает курсор в виде синего прямоугольника и построчно отрисовывает синюю же вертикальную полосу. Рисует медленно, около минуты и только потом на экран выводится картинка. На каком посте это происходит отпишу завтра, если интересно. После прохождения поста машина грузится, работает нормально. Винт 80-ку определяет махом. Итак за исключением синей полосы все отлично, цель достигнута.
Да, патчеры пробовались 4.23, 4.51
После видяшкиного биоса
20-30 секунд, разогрев двигателей:)
1 минута, полет нормальный:)
Фоткалось мобилой, качество оставляет желать, но и так все видно.
Jazz, Blues & Rock'n'Roll фарева!
EPA Logo-то удалено - вот и чудит.
Возможно, имеет смысл пожертвовать не им, а тем же sis530.vga, если уж всё скопом не помещается. Я так понял - оно нафиг не нужно на данный момент.
Конечно!
Т.к. заранее неизвестно, какая будет VGA-карта, все делалось из соображений сберечь sis530.vga.
Можно VGA BIOS выбросить, EPA Logo - вернуть...
Если бы можно было выбросить VGA, я бы сделал это в первую очередь. Он и был первым кандидатом. Просто я не догадался сделать именно такой финт с удалением и последующим возвращением модулей. А т.к. компьютер работает печатной машинкой - работает на встроенной видяхе.
Ну машину и так забрали, довольны.
Всем спасибо.
Вопрос ко владельцам данного девайса! Отрыл в загашниках эту матплату, поменял мосфеты и она стартанула (ранее была мертва). Но вот проблема! От неё нет VGA шлейфа, а в БИОС стоит приоритетом встроенное видео. Вопрос в том, как запустить мать на PCI видеокарте? Есть ли возможность отключить эту видяху или может её вообще демонтировать?
Заранее благодарен.
Везение есть, а знания накопим =)
Начинающий копатель
1. Можно подредактировать BIOS для того, чтобы первой инициализировалась PCI видеокарта
2. Можно попробовать выбросить из BIOS'а модуль видеоBIOS'а
3. Можно сделать шлейф самостоятельно (первое тупое предположение - pin-to-pin от внутреннего разъема IDC-16 к внешнему DSub-15, хотя отследить характерные контакты по распиновке DSub-15 не составляет труда)
