Привет всем!
WARNING: SET MULTIPLE command aborted. Maxtor 6E030L0 LBA:60,058,656 SN:E19EWCAE FW:NAR6159Z CACHE:2048KB Size = 29325MB To see enhanced information, use command EID <SHIFT+F2> Init drive: [RESET] ! ERROR: Drive not responding or operation canceled [RECAL] ! ERROR: Drive not responding or operation canceled
[PRE]
51 ERR INDX CORR DREQ DRSC WRFT DRDY BUSY HPA AMNF T0NF ABRT IDNF UNCR BBK 04
[Maxtor 6E030L0 ] [ 60,058,656] [ 2,054,790] [ EST: 04:36 ]
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ACT [125983 kb/s]
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ░ <3ms :
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ▒ <10ms :
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ▓ <50ms :
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! █ <150ms:
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! █ <500ms:
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! █ >500ms:
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ? TIME :
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! x UNC :
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ! ABRT : 8058
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! S IDNF :
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! A AMNF :
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 0 T0NF :
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! * BBK :
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! [ 3.0% ] [ 3.0% ]
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Error: 2053515
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Error: 2053770
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Error: 2054025
Error: 2054280
Last scanned LBA: 2055044 Error: 2054535
SMART посмотреть нельзя.
Что может быть с винтом?
Посоветуйте что-нить с починкой если такое возможно![]()
Заранее спс.
смотри служебку , Дефекть листы , модули смарта и транслятор
Я новичок в этом деле и прошу не бить
Искал весь день, но так и не нашел с помощью чего это можно сделать в домашних условиях. Можно ссылочку на инфу? Читат и понимать я умею
Что интересно у него после каждой операции с винтом становитсярегистр состояния err и регистр ошибок abrt...
Диск залочился в результате какой-либо серьёзной внутренней ошибки. В результате к пользовательской зоне не пускает. Отсюда ерроры и аборты.
Чтобы самостоятельно её определить, устранить и поправить firmware требуется минимум год самостоятельно изучать винтостроение (сюда входит и понимание слэнга ремонтников).
А стоит ли это одного диска?
Мораль:
- если важна инфа - диск к ремонтнику;
- если важен сам диск - а стоит ли это 30ГБ? Тем более что все максторы данной модели, как мамонты, вымрут все со временем;
- если важен сам процесс - изучите вначале форумы, лишь потом сможете задать узкоспециализированные вопросы, на которые не факт, что получите ответы, да и то намёками.
Может у Вас как раз та ситуация, которая уже никак не лечится? (например, запилы).
Тогда всё время насмарку.
хм. стока форумов перерыл. тока вы мне ответили на это вопрос.
Время есть и много. Появилось оно у меня с мая месяца...
Сленг я понимать ужо начал...3 дня форумы читаю. Про строение тоже читаю, но инфы чета мало.
Инфа не нужна, она давно слита, когда смарт фигню выдавал.
Винт не нужен, идет как подопотеый кролик.
Как раз процесс то и важен. Винт достат из долгого ящика, где еще лежит несколько
Ну и пусть как вы говорите насмарку
HDD восстановлен...
Чего ж не написали каким образом ?
В данную минуту тестю винт ВД 320гиг таже муть при тестировке МХДД 4.6.
Суть: Стоял в домашнем сервере, торенто файловая помойка все такое, месяц без ребута все это отстояло, потом в один день перестал пинговатся, ребутнул не пологло. Короч подрубил его на третий раз запустился, грешил на мать вмазанный пост на FF стоит даж после запуска выни, поменял мать все хорошо тест садо мазы прошел, шачинаю лить по сети файло, ошибка записи и синька.
Один винт протестил тож ВД ток на 80 норм, вот на 320 ща затык. Пока тестится, но видимо ему дорога по гарантии в СЦ. Ща еще до СМАРТа доберусь чувствую просто офигею когда увижу.
Автор поделитесь как полечили, интересно
