Имя модели : IC35L020AVVN07-0
Дескриптор семейства : VA1O
m-Code : VAUOAF0C
Код версии МП : 6642887D
Страшно шуршит головами, долго висит в бизи.
При проверке служебки жуть, вот лог
ID Start ABA Size Addr(Mem) Length(byte) State
PSHT $0FFE3000 $00A0 $00080000 $0000 RD:-, ID:-
RDMT $0FFE30A0 $0020 $0002C000 $4000 RD:v, ID:v
RLBA $0FFE1093 $0001 $00035600 $00DC RD:v, ID:v
CNSL $0FFE107F $0001 $0003DD46 $00C6 RD:v, ID:-
RWCN $0FFE1080 $0001 $0003D95A $006E RD:-, ID:-
CHNM $0FFE109B $0012 $00037200 $23A4 RD:v, ID:v
SRVP $0FFE1083 $0001 $00039840 $013E RD:v, ID:-
SRVM $0FFE1094 $0007 $00039A40 $0D50 RD:v, ID:v
ZONE $0FFE108F $0003 $0003C480 $0444 RD:-, ID:-
PTRT $0FFE1092 $0001 $00035400 $01E0 RD:v, ID:v
RAM0 $0FFE1002 $0030 $0004C000 $6000 RD:-, ID:-
OVR1 $0FFE1032 $004B $00052000 $1E00 RD:-, ID:-
SMRT $0FFE1087 $0001 $00037040 $00BB RD:v, ID:-
MLBA $0FFE1088 $0001 $0003DCF6 $0026 RD:v, ID:v
SECI $0FFE1089 $0001 $00035B00 $004A RD:v, ID:-
SRIF $0FFE1084 $0001 $0003DD32 $0002 RD:v, ID:v
SERL $0FFE108B $0003 $00036400 $0600 RD:v, ID:v
IDNT $0FFE1081 $0001 $00039600 $0214 RD:v, ID:v
DCOT $0FFE108A $0001 $0003DD1C $000A RD:-, ID:-
PTCH $0FFE107D $0002 $00053E00 $0400 RD:-, ID:-
USAG $0FFE1000 $0002 $000FFFFF $0000 RD:-, ID:-
Holes : 4
ID Start ABA Size RD
##01 $0FFE1082 $0001 -
##02 $0FFE1085 $0002 v
##03 $0FFE108E $0001 v
##04 $0FFE10AD $0053 -
Таблица открытых модулей (RD![]()
Модуль RSVD : Стартовый модуль (RD:-, ID![]()
Модуль ZONE : Таблица зон (RD:v, ID:v)
# Start LBA SPC St.Cyl En.Cyl SPT
0 $00000000 $03D8 $0000 $06D5 $03D8
1 $001A3EE0 $03D3 $06D6 $0D97 $03D3
2 $00340F20 $03C0 $0D98 $144F $03C0
3 $004D39A0 $03C0 $1450 $1C33 $03C0
4 $006AC920 $03A4 $1C34 $2309 $03A4
5 $0083A894 $0399 $230A $29C1 $0399
6 $009BCD5A $0390 $29C2 $306F $0390
7 $00B3921A $037A $3070 $371D $037A
8 $00CAC78C $0373 $371E $3DCB $0373
9 $00E1CAD0 $0360 $3DCC $4537 $0360
10 $00FAD090 $0352 $4538 $4BDB $0352
11 $0110D9C6 $0340 $4BDC $52E3 $0340
Модуль MLBA : Таблица MLBA (RD:v, ID:v)
MaxLBA : 40188960
Ограничитель MaxLBA : 40188960
Логические параметры :
Цилиндров : 16383
Головок : 16
Секторов : 63
Модуль IDNT : Таблица IDNT (RD:v, ID:v)
Таблица серийного номера (RD![]()
Модуль SRVM : Таблица SRVM (RD:v, ID:v)
Цилиндровые дефекты :
Количество дефектов : 27
Модуль RDMT : Таблица дефектов (G-List) (RD:v, ID:v)
Емкость таблицы : 1899
Количество цепочек : 0
Из них Grown Defects : 0
Модуль DUMP : SRST dump table parameters (RD:v, ID![]()
Указатель на следующий результат : 30583
Общее количество страниц : 30583
Карта страниц :
Заголовок Старт. стр. Страниц Головка Цилиндр К-во сэмплов
wwww 30583 30583 30583 30583 30583
Причем в следующий раз может считать другие модули. NV-RAM, ПЗУ, ц-код отдает. Все совпадает. Убита служебка? Что в этом случае делать?
Вот другой лог
RDMT $0FFE30A0 $0020 $0002C000 $4000 RD:-, ID:-
RLBA $0FFE1093 $0001 $00035600 $00DC RD:v, ID:-
RWCN $0FFE1080 $0001 $0003D95A $006E RD:v, ID:-
SRVM $0FFE1094 $0007 $00039A40 $0D50 RD:v, ID:-
ZONE $0FFE108F $0003 $0003C480 $0444 RD:v, ID:-
PTRT $0FFE1092 $0001 $00035400 $01E0 RD:v, ID:-
MLBA $0FFE1088 $0001 $0003DCF6 $0026 RD:v, ID:-
SRIF $0FFE1084 $0001 $0003DD32 $0002 RD:v, ID:-
SERL $0FFE108B $0003 $00036400 $0600 RD:-, ID:-
IDNT $0FFE1081 $0001 $00039600 $0214 RD:v, ID:-
Holes : 4
##01 $0FFE1082 $0001 v
Добавлено спустя 27 минут 19 секунд:
Забыл сказать, контакты на плате пропаял. Корейца прожарил, и на всякий случай перепаял
Дык...служебочку ему для начала восстановите полностью...
Все люди, как люди...один я чатланин !!!
r.carnage.ru/?1000698908
Пробовал, несколько сервотреков (Main и RSVD помоему) выдают "ошибка восстановления". Я с IBM до этого не работал. Эти сервртреки вручную скрывать надо?
Когда-то деревья были большими, а мы были маленькими. Мы не умели говорить и писали прямо в штаны.
MainНе помню такого модуля...Пока RSVD не восстановите должным образом, с оставшейся служебкой ничего не выйдет...
Пробуйте брать от какого-нить комплекта и перепишите его...может имеет смысл СА назначить на другую голову...(перекоммутировать)...
Так это двадцатка одноголовая
точно...сорри...на модель толком не посмотрел...
Восстановление служебной области приводит к этому:
Ошибка очистки сервотрека Cyl: FFE9; Head: 0 (main)
Ошибка очистки сервотрека Cyl: FFEA; Head: 0 (main)
Ошибка очистки сервотрека Cyl: FFEB; Head: 0 (RSVD)
Ошибка очистки сервотрека Cyl: FFEB; Head: 0 (main)
Ошибка очистки сервотрека Cyl: FFF3; Head: 0 (main)
Ошибка очистки сервотрека Cyl: FFF4; Head: 0 (main)
или так:
Ошибка очистки сервотрека Cyl: FFE9; Head: 0 (RSVD)
Ошибка очистки сервотрека Cyl: FFEA; Head: 0 (RSVD)
Ошибка очистки сервотрека Cyl: FFF4; Head: 0 (RSVD)
... да кареец это чудит... жарь, не жарь. тайванец вон сёдня,...прям на руках скончался... а после "сауны" вроде ожил был... но не надолго
Корейца пересадил, поставил на очистку служебки. Пока на слух ощущений не ощутил, головами шуршит, цилиндры перебирает медленно. Ждемс результата.
Добавлено спустя 1 минуту 46 секунд:
Я имел ввиду изменений не ощутил.
2 Alex K
Не всё золото , что блестит.;)
Рекомедация .... пустите кролика на запчасти ... отжил он своё!
Серёзно!
Я тоже так думаю. Кореец ни при чем, пересаженый ведет себя так же. Наверное всетаки либо голова, либо блин. Увы. Может кто подкинет схемку и прогу чем перешить le25fv101, программатор дороговато становится. Я платку поюзал еще.
