HD322GJ spinpoint rev.A
p/n : 63013-E11A-A30U8
на банке: BNF40221
pcb:F4 S3M
ActiveFW : 00 FWVer : 0001 DDR size detected = 16MB SATA PLL cal done *PA VID=0004 PN=0028 Rev=0003- 885x Found *PA VID=0004 PN=0028 Rev=0003- 885x Found U S_0 RV Sensor Circuit Enabled Shock Sensor Circuit Enabled SO_1 SpinStartUp: mcSpinRPM = 48 RPM at Handoff: 632 Temp : 25 degC SpinInt not Enabled or Served! 0000A8B8 632 SpinInt not Enabled or Served! 0000A8B8 632 SpinInt not Enabled or Served! 0000A8B8 632 SpinInt not Enabled or Served! 0000A8B8 632 SpinInt not Enabled or Served! 0000A8B8 632 Spin ISR Off at accel1 <MDL_SVO_SpinCheckReady_1> mfAccelRty = 1 RPM = 632 SpinStartUp: mcSpinRPM = 570 RPM at Handoff: 806 Temp : 25 degC SpinInt not Enabled or Served! 0000A8B8 806 SpinInt not Enabled or Served! 0000A8B8 68 SpinInt not Enabled or Served! 0000A8B8 68 SpinInt not Enabled or Served! 0000A8B8 68 SpinInt not Enabled or Served! 0000A8B8 68 Spin ISR Off at accel1 <MDL_SVO_SpinCheckReady_1> mfAccelRty = 2 RPM = 78 SpinStartUp: mcSpinRPM = 705 RPM at Handoff: 877 Temp : 25 degC <MDL_SVO_SpinCheckReady_4> SpinOnRty mfCOMSENSRty = 0, mAccelTry = 2, RPM = 13950 SO_2 C=0,A=2,S=1,RPM=13950 SpinStartUp: mcSpinRPM = 48 RPM at Handoff: 624 Temp : 25 degC SpinInt not Enabled or Served! 0000A8B8 66 SpinInt not Enabled or Served! 0000A8B8 66 SpinInt not Enabled or Served! 0000A8B8 66 SpinInt not Enabled or Served! 0000A8B8 66 SpinInt not Enabled or Served! 0000A8B8 52 Spin ISR Off at accel1 <MDL_SVO_SpinCheckReady_1> mfAccelRty = 1 RPM = 52 SpinStartUp: mcSpinRPM = 48 RPM at Handoff: 675 Temp : 25 degC <MDL_SVO_SpinCheckReady_4> SpinOnRty mfCOMSENSRty = 0, mAccelTry = 1, RPM = 13950 SO_2 C=0,A=1,S=2,RPM=13950 SpinStartUp: mcSpinRPM = 48 RPM at Handoff: 621 Temp : 25 degC SpinInt not Enabled or Served! 0000A8B8 54 SpinInt not Enabled or Served! 0000A8B8 56 SpinInt not Enabled or Served! 0000A8B8 56 SpinInt not Enabled or Served! 0000A8B8 56 SpinInt not Enabled or Served! 0000A8B8 56 Spin ISR Off at accel1 <MDL_SVO_SpinCheckReady_1> mfAccelRty = 1 RPM = 56 SpinStartUp: mcSpinRPM = 48 RPM at Handoff: 682 Temp : 25 degC <MDL_SVO_SpinCheckReady_4> SpinOnRty mfCOMSENSRty = 0, mAccelTry = 1, RPM = 13950 SO_2 C=0,A=1,S=3,RPM=13950 SO_3 R Sp Err SpinUp Fail VOP! PK_4 C: 0 H:0 LED 1703 ...
| Вложение | Размер |
| hd322gj-s2bjj90z620993.rar | 707.79 КБ |
Это из последних семейств самсунгов F1-F4 бурн комплектов в открытом доступе не найдёте,как впрочем и софт.
да и бурн запустить не так уж и просто на них
SpinUp Fail
проблема с крутилкой ! SH6125B
Пока не будет--SpinUp OK, он даже головы не распаркует.
