Грабли с Радиусом
Такой расклад:
mpd 3.18(FreeBSD6.0)
freeradius(Win2k3SP1)
При коннекте говорит что ошибка 718, Сервер не ответил вовремя...
Сдаётся мне как-то не корректно сконфигурирован радиус или клиенское соединение...
Вот скрины...
personal.primorye.ru/lsv/img/client_connect.bmp
personal.primorye.ru/lsv/img/radius.bmp
И лог mpd...
Nov 21 04:40:08 test mpd: mpd: pid 419, version 3.18 (root@test 03:35 21-Nov-2005)
Nov 21 04:40:08 test mpd: mpd: already running as process 196
Nov 21 04:41:54 test mpd: mpd: PPTP connection from 192.168.0.96:2428
Nov 21 04:41:54 test mpd: pptp0: attached to connection with 192.168.0.96:2428
Nov 21 04:41:54 test mpd: [pptp0] IFACE: Open event
Nov 21 04:41:54 test mpd: [pptp0] IPCP: Open event
Nov 21 04:41:54 test mpd: [pptp0] IPCP: state change Initial --> Starting
Nov 21 04:41:54 test mpd: [pptp0] IPCP: LayerStart
Nov 21 04:41:54 test mpd: [pptp0] bundle: OPEN event in state CLOSED
Nov 21 04:41:54 test mpd: [pptp0] opening link "pptp0"...
Nov 21 04:41:54 test mpd: [pptp0] link: OPEN event
Nov 21 04:41:54 test mpd: [pptp0] LCP: Open event
Nov 21 04:41:54 test mpd: [pptp0] LCP: state change Initial --> Starting
Nov 21 04:41:54 test mpd: [pptp0] LCP: LayerStart
Nov 21 04:41:54 test mpd: [pptp0] device: OPEN event in state DOWN
Nov 21 04:41:54 test mpd: [pptp0] attaching to peer's outgoing call
Nov 21 04:41:55 test mpd: [pptp0] device is now in state OPENING
Nov 21 04:41:55 test mpd: [pptp0] device: UP event in state OPENING
Nov 21 04:41:55 test mpd: [pptp0] device is now in state UP
Nov 21 04:41:55 test mpd: [pptp0] link: UP event
Nov 21 04:41:55 test mpd: [pptp0] link: origination is remote
Nov 21 04:41:55 test mpd: [pptp0] LCP: Up event
Nov 21 04:41:55 test mpd: [pptp0] LCP: state change Starting --> Req-Sent
Nov 21 04:41:55 test mpd: [pptp0] LCP: phase shift DEAD --> ESTABLISH
Nov 21 04:41:55 test mpd: [pptp0] LCP: SendConfigReq #1
Nov 21 04:41:55 test mpd:  ACFCOMP
Nov 21 04:41:55 test mpd:  PROTOCOMP
Nov 21 04:41:55 test mpd:  MRU 1500
Nov 21 04:41:55 test mpd:  MAGICNUM 633e1ac0
Nov 21 04:41:55 test mpd:  AUTHPROTO CHAP MSOFTv2
Nov 21 04:41:55 test mpd:  MP MRRU 1600
Nov 21 04:41:55 test mpd:  MP SHORTSEQ
Nov 21 04:41:55 test mpd:  ENDPOINTDISC [802.1] 00 03 ff 5b be a7
Nov 21 04:41:55 test mpd: pptp0-0: ignoring SetLinkInfo
Nov 21 04:41:55 test mpd: [pptp0] LCP: rec'd Configure Request #0 link 0 (Req-Sent)
Nov 21 04:41:55 test mpd:  MRU 1400
Nov 21 04:41:55 test mpd:  MAGICNUM 48425dca
Nov 21 04:41:55 test mpd:  CALLBACK
Nov 21 04:41:55 test mpd:    Not supported
Nov 21 04:41:55 test mpd: [pptp0] LCP: SendConfigRej #0
Nov 21 04:41:55 test mpd: [pptp0] LCP: rec'd Configure Request #1 link 0 (Req-Sent)
Nov 21 04:41:55 test mpd: [pptp0] LCP: SendConfigAck #1
Nov 21 04:41:55 test mpd: [pptp0] LCP: state change Req-Sent --> Ack-Sent
Nov 21 04:41:58 test mpd: [pptp0] LCP: SendConfigReq #2
Nov 21 04:41:58 test mpd:  ACFCOMP
Nov 21 04:41:58 test mpd:  PROTOCOMP
Nov 21 04:41:58 test mpd:  MRU 1500
Nov 21 04:41:58 test mpd:  MAGICNUM 633e1ac0
Nov 21 04:41:58 test mpd:  AUTHPROTO CHAP MSOFTv2
Nov 21 04:41:58 test mpd:  MP MRRU 1600
Nov 21 04:41:58 test mpd:  MP SHORTSEQ
Nov 21 04:41:58 test mpd:  ENDPOINTDISC [802.1] 00 03 ff 5b be a7
Nov 21 04:41:58 test mpd: [pptp0] LCP: rec'd Configure Reject #2 link 0 (Ack-Sent)
Nov 21 04:41:58 test mpd: [pptp0] LCP: SendConfigReq #3
Nov 21 04:41:58 test mpd: [pptp0] LCP: rec'd Configure Ack #3 link 0 (Ack-Sent)
Nov 21 04:41:58 test mpd: [pptp0] LCP: state change Ack-Sent --> Opened
Nov 21 04:41:58 test mpd: [pptp0] LCP: phase shift ESTABLISH --> AUTHENTICATE
Nov 21 04:41:58 test mpd: [pptp0] LCP: auth: peer wants nothing, I want CHAP
Nov 21 04:41:58 test mpd: [pptp0] CHAP: sending CHALLENGE
Nov 21 04:41:58 test mpd: [pptp0] LCP: LayerUp
Nov 21 04:41:58 test mpd: pptp0-0: ignoring SetLinkInfo
Nov 21 04:41:58 test mpd: [pptp0] LCP: rec'd Ident #2 link 0 (Opened)
Nov 21 04:41:58 test mpd:  MESG: MSRASV5.10
Nov 21 04:41:58 test mpd: [pptp0] LCP: rec'd Ident #3 link 0 (Opened)
Nov 21 04:41:58 test mpd:  MESG: MSRAS-0-VEGA_1
Nov 21 04:41:58 test mpd: [pptp0] CHAP: rec'd RESPONSE #1
Nov 21 04:41:58 test mpd:  Name: "longhorn"
Nov 21 04:41:58 test mpd: [pptp0] RADIUS: using /etc/radius.conf
Nov 21 04:41:58 test mpd: [pptp0] RADIUS: RadiusAddServer Adding 192.168.0.4
Nov 21 04:41:58 test mpd: [pptp0] RADIUS: RadiusPutAuth: RADIUS_CHAP (MSOFTv2) peer name: longhorn
Nov 21 04:43:00 test mpd: [pptp0] RADIUS: RadiusSendRequest: rad_send_request failed No valid RADIUS responses received
Nov 21 04:43:00 test mpd: [pptp0] CHAP: sending FAILURE
Nov 21 04:43:00 test mpd: [pptp0] LCP: authorization failed
Nov 21 04:43:00 test mpd: [pptp0] device: CLOSE event in state UP
Nov 21 04:43:00 test mpd: pptp0-0: clearing call
Nov 21 04:43:00 test mpd: pptp0-0: killing channel
Nov 21 04:43:00 test mpd: [pptp0] PPTP call terminated
Nov 21 04:43:00 test mpd: [pptp0] IFACE: Close event
Nov 21 04:43:00 test mpd: [pptp0] IPCP: Close event
Nov 21 04:43:00 test mpd: [pptp0] IPCP: state change Starting --> Initial
Nov 21 04:43:00 test mpd: [pptp0] IPCP: LayerFinish
Nov 21 04:43:00 test mpd: pptp0: closing connection with 192.168.0.96:2428
Nov 21 04:43:00 test mpd: pptp0: write: Broken pipe
Nov 21 04:43:00 test mpd: pptp0: killing connection with 192.168.0.96:2428
Nov 21 04:43:00 test mpd: [pptp0] device is now in state CLOSING
Nov 21 04:43:00 test mpd: [pptp0] CHAP: rec'd RESPONSE #1
Nov 21 04:43:00 test mpd:  Not expected, but that's OK
Nov 21 04:43:00 test mpd:  Name: "longhorn"
Nov 21 04:43:00 test mpd: [pptp0] RADIUS: using /etc/radius.conf
Nov 21 04:43:00 test mpd: [pptp0] RADIUS: RadiusAddServer Adding 192.168.0.4
Nov 21 04:43:00 test mpd: [pptp0] RADIUS: RadiusPutAuth: RADIUS_CHAP (MSOFTv2) peer name: longhorn
Nov 21 04:44:01 test mpd: [pptp0] RADIUS: RadiusSendRequest: rad_send_request failed No valid RADIUS responses received
Nov 21 04:44:01 test mpd: [pptp0] CHAP: sending FAILURE
Nov 21 04:44:01 test mpd: [pptp0] error writing len 17 frame to bypass: Network is down
Nov 21 04:44:01 test mpd: [pptp0] LCP: authorization failed
Nov 21 04:44:01 test mpd: [pptp0] bundle: CLOSE event in state OPENED
Nov 21 04:44:01 test mpd: [pptp0] closing link "pptp0"...
Nov 21 04:44:01 test mpd: [pptp0] device: DOWN event in state CLOSING
Nov 21 04:44:01 test mpd: [pptp0] device is now in state DOWN
Nov 21 04:44:01 test mpd: [pptp0] error writing len 12 frame to bypass: Network is down
Nov 21 04:44:01 test mpd: [pptp0] CHAP: rec'd RESPONSE #1
Nov 21 04:44:01 test mpd:  Not expected, but that's OK
Nov 21 04:44:01 test mpd:  Name: "longhorn"
Nov 21 04:44:01 test mpd: [pptp0] RADIUS: using /etc/radius.conf
Nov 21 04:44:01 test mpd: [pptp0] RADIUS: RadiusAddServer Adding 192.168.0.4
Nov 21 04:44:01 test mpd: [pptp0] RADIUS: RadiusPutAuth: RADIUS_CHAP (MSOFTv2) peer name: longhorn
