На оверклокерсах и хоботе помочь пока не смогли, суппорт абита молчит хотя я уже 2 письма отправил.
Я: Hello, sorry for bad english. I have the a problem with booting OS on following configuration: abit AV8 mb, ultra 100tx2(bios 2.20.0.15, drivers 2.00.0.42) with 2hdd on primary onboard ide PATA channel, 2 dvd-rw on secondary channel, 2 hdd on primary channel of ultra 100tx2, and dvd-rom on secondary channel of ultra 100tx2. After ultra100tx2 bios initialization and detection of drives, last portion of post-screen appears and then it just go black screen and nothing happens. I have win2000 server sp4 installed. If no hdd's connected to ultra 100tx2 and it says that it's bios not installed, then all works fine but in windows optical drives connected to ultra100tx2 work only in PIO mode. The same problem was on MSI K8N Neo2-FX, but was ok on ASUS A7N8X Deluxe. I've tried to disable "boot other device" option in bios, disable drives connected to ultra 100tx2 in mb bios, disable SATA controller, and all other related options, nothing solved the problem. I think the problem is in conflict by ultra 100tx2 and onboard chipset ide-native SATA controller. There is a Silicon Image SATA controller on ASUS A7N8X Deluxe, but it caused no problem even if i do not disable it. Can you suggest something? Or maybe provide me with new bios version? Thank you.
Они:
Case Solution:
if you have any RAID controller you need to disable it. yes the cdrom and dvdrom drives will only work in PIO mode. cdrom players can best be attached to your motherboard diect. there is unfortunately no newer BIOS version for this card. also placing the card to another slot might help sometimes.
На хоботе тоже посоветовали переставить его в другие слоты но мне не помогло. Не помогло и отключение SATA RAID в биос.
Пробовал подключать системный винт к промайзу и пробовал загрузиться только с 1 винтом. Нифига не помогает.
Думается проблема в том что на старой матери sata было сделано в качестве raid-контроллера и поэтому не мешалось, к тому же я его джампером отрубал нафик. Хотя и при врубленном проблема вроде не наблюдалось. На новых же матерях sata чипсетное и работает в native-mode(слышал такое умное слово но понимаю его довольно абстрактно), поэтому как-то оно конфликтует с биосом промайза. В принципе мне sata не нужно нафик. 4 винта мне вполне достаточно будет в ближайшем времени, тем более что ещё одна дырка в промайзе свободна а 2 из винтов по 30 и 40 гб.
Не подскажите чего-нибудь?
Да, ось - win2k server sp4, со всеми апдейтами. Биос на матери последний но пробовал зашивать те на которых у людей всё работало нормально с промайзом. Вроде все вводные данные написал...
Думается мне - мать и промайз дерутся за INT13, в результате чего система становится раком.
Я бы как-нибудь загадил BIOS промайза, чтобы он не всплывал (или всплывал, но ничего не делал, сразу назад). Загрузиться с него, конечно станет невозможно, но в винде (когда поднимутся драйвера), скорее всего, будет работать.
Вот что мы имеем
CBROM V2.07 (C)Award Software 2000 All Rights Reserved. ******** AV8_27.BIN BIOS component ******** No. Item-Name Original-Size Compressed-Size Original-File-Name ================================================================================ 0. System BIOS 20000h(128.00K)1309Dh(76.15K)AV8_27.BIN 1. XGROUP CODE 0E760h(57.84K)09E91h(39.64K)awardext.rom 2. CPU micro code 02000h(8.00K)00390h(0.89K)CPUCODE.BIN 3. ACPI table 05106h(20.26K)01BF1h(6.99K)ACPITBL.BIN 4. EPA pattern 0168Ch(5.64K)002AAh(0.67K)AwardBmp.bmp 5. YGROUP ROM 0BE80h(47.62K)04880h(18.12K)awardeyt.rom 6. GROUP ROM[ 0] 053A0h(20.91K)02487h(9.13K)_EN_CODE.BIN 7. Other(40B5:0000) 01B90h(6.89K)00CCDh(3.20K)_ITEM.BIN 8. PCI driver[A] 06975h(26.36K)04A58h(18.59K)uav8_022.bin 9. PCI driver[B] 0A000h(40.00K)06255h(24.58K)VIAPXE.LOM 10. Other(4067:0000) 029DEh(10.47K)00C1Bh(3.03K)AGESACPU.939 11. PCI driver[C] 10000h(64.00K)07B56h(30.83K)237R493.rom 12. LOGO BitMap 4B30Ch(300.76K)0349Ah(13.15K)ABIT939logo.bmpА, может, сделать по-другому - выкинуть из мамкиного BIOS кое-что? Под подозрением 11. PCI driver[C]... Угу, он и есть... uav8_022.bin - какая-то фигня непонятная, VIAPXE.LOM - сетка
А из шаманства - попробуй вырубить USB-контроллеры. Почему - не спрашивай
А кому счас легко...
Думаю да, но что-то подсказывает что опять всё будет только в PIO. :?
Выкинуть - в смысле запчасти от sata-контроллера? А оно как себя поведёт от этого?
Попробую. Если что то хотсвапом уже перешивал ту микростарину, зашью и тут. Устрою сегодня оргию деструкции.
Это я читал что у них там глюк и когда вырубаешь то на самом деле отрубается raid.
запчасти от SATA - это PCI driver [C] - по характерному 237R
Ибо юг VT8237R...
Выход обычно есть. Но он не работает.
USB попробовал вырубить, не помогло. Как выдрать эту фигню от SATA пока не понял.
Качаешь отсюда cbrom.exe (ссылка на первой странице)
Потом
cbrom AV8_27.BIN /pci release, как спросит - скажешь "С".
Вроде все...
А как CRC пересчитать? Шиться не хочет ни FlashMenu ни awardflash-ем.
Вообще мать конечно комическая. Ни с того ни с сего иногда при ресете начинает пищать. Сейчас вот не получилось прошиться под досом, надавил ресет, а оно пищит длинными гудками и не вырубается сколько ни держи повер. Пришлось на бп вырубать питание. После этого нормально включилась.
Cerebron
1) Не надо ничего никуда пересчитывать - CBROM "правильной" версии все сам пересчитает (кстати, не надо путать чексуму и CRC);
2) История про "комическую" мать наводит на мысль, что у оной на железном уровне не все в порядке...
- Ситчик веселенький есть?..
- Приезжайте, обхохочетесь!..
Да, это я чего-то ступил. Читаю ведь какая версия для каких авардов и пользую не ту.
В общем отредактировал сейчас версией 6.06. Посмотрел с ключом /D, оно там отсутствует. Зашил. Ничего не изменилось.
Cerebron
А кто говорил про версию 6.06???
2.07/2.08, либо (для совсем "уж сильно шибко новых") CBROM32...
Эээ... Дык я сначала 2.07 и попробовал. И 2.15 пробовал. После этого и абитовский прошивальщик и awardflash ругаются что чексум эррор и шить они не будут. После 6.06 всё нормально.
