Автор: Pinczakko , 10 ноября 2006
Hi,
I'm currently modifying FIC VB609 motherboard (very old motherboard from 1995/1996). I've tried to modify it by using AMIBCP v7.60.04 (AMIBCP released in year 2002). But the BIOS binary result failed to boot, not even get into POST.
I will try to use AMIBCP v7.00.b11, v7.00.b12 and v7.01.01. If anyone have experience please share it :wink: .
Moreover, which AMIBCP version that is known to work for motherboard relased in that time frame (1996/1997)?
I haven't disassemble the file. I think it's probably AMIBIOS5 code.
Thx in advance,
Pinczakko
icbook
19 лет 12 месяцев назад
Link for BIOS, please!
Pinczakko
Because I can't find it anywhere in the web, I upload it to:
http://www.megaupload.com/?d=EYSRXTRO
and if you have problems with mega upload, you can download it from:
http://www.geocities.com/mamanzip/Download/bios_v1_16.zip
Anyway, Icbook, I know you have been working with old and new AMIBIOS versions for a long time. Do you have any suggestion how to work with this old BIOS?
I may made a mistake by running AMIBCP v7.60 and its older siblings in windows XP SP2 (V86 mode of course). I will try to run it on DOS today :(.
icbook
19 лет 11 месяцев назад
This is true AMIBIOS, core V6.27. You can startnig from AMIBCP v6.25 and go higher. I hope BCP v7.00.beta10/v7.00.beta12 is more suitable for this.
I do not work under Windows XP and I have not any idea about compatibility AMIBCP and XP.
Pinczakko
... You can startnig from AMIBCP v6.25 and go higher. I hope BCP v7.00.10/v7.00.10 is more suitable for this.
Any URL to download these older versions of AMIBCP? The oldest one that I have is AMIBCP v7.00.beta11 (from BNOBTC back then) :?
icbook
It must be good...
Pinczakko
AMIBCP version 7.01.01 works just fine. Anyway, because I don't have any windows 98 or DOS on my notebook and I have NTFS partitions. I would like to try running DOS in MS Virtual PC and then the AMIBCP in the DOS in the virtual PC, then used shared folders facility to write the result to my NTFS harddrive. Have anyone try this? I would like to know the result if you have done so.
Doing something that must be done on PC running DOS when you are on the move is very annoying :wink:
DanZer
Why don't you just use bootable CD and a RAM-drive (virtual disk in RAM)? If your notebook has USB support in BIOS - you can use a flashdrive instead.
Pinczakko
It's more convenient for me if I can do it inside a running windows system (I need to do something that's better if being worked on alongside the BIOS modification process. I need to be able to switch back and forth between the BIOS modification and the windows based works). However, because I couldn't make it work, USB flashdrive is my last resort (this one was working) :roll:
DanZer
Ok, maybe this article will help you :roll:
