Вот, отцы, все что просили, но пробегая глазами, я
я ничего незаконного или злого, что могло привести к глюкам
не вижу.
Soft Menu II Setup -
Cpu Operating Speed 733(133)
System Memory Frequecy 133MHz
CPU Power Supply CPU Default
In-Order Queue Depth 4
Speed Spectrum Modulated Disabled
Standart CMOS Features -
IDE Primary Master - Samsung SP1604N Auto Lba
IDE Primary Slave - Samsung SP1204H Auto Auto
IDE Secondary Master CD-W58E Auto Auto
IDE Secondary Slave Asus Auto Auto
Video EGA/VGA
Halt On No Error
Adwanced Bios Features -
Virus Warning Disabled
Cpu Level 1 Cache Enabled
Cpu Level 2 Cache Disabled
CPU L2 Cache ECC Checking Disabled
Processor Number Feature Enabled
Quick Power On Self Test Enabled
Typermatic Rate Setting Disabled
Delay IDE Initial 0
Advanced Chipset Features-
SDRAM CAS Latency Time 3
SDRAM Cycle Time TransTrc 7/9
SDRAM RAS-to-CAS Delay 3
SDRAM RAS Precharge Time 3
System Bios Cacheble Disabled
Video Bios Cacheble Disabled
Memory Hole At 15M-16M Disabled
CPU Latency Timer Enabled
Onboard VGA Enabled
AGP Graphics Aperture Size 64mb
Intergreted Perpheraps-
Onboard IDE 1,2 Controller - Enabled, все на Auto
Init Display First Onboard/AGP
Onboard AC97 Codec Auto
AC97 Audio Auto
AC97 Modem Disabled
IDE HDD Block Mode Enabled
Onboard IR Function Disable
Onboard Paraller Port 378/IRQ7
Paraller Port Mode SPD
PWRON Alert PWR-FAil Off
Game Port Adress 201
Midi Port Adress 330
Midi Port IRQ 10
Power Managment-
ACPI Suspend Type S1(POS)
Power Managment User Define
Suspend mode Disabled
HDD Power Down Disabled
Video Off Method DPMS
VIdeo Off in Suspend Yes
Suspend Type Stop Grant
Modem Use IRQ NA
Soft-Off By PWR-BTTN-Instant Off
CPU Thermal-Throwling 62.5%
Reload Global Timer Events все Disabled
PNP/PCI Configurations-
Resources Controlled By Auto(ESCD)
PCI/VGA Pallete Snoop Disabled
Assing IRQ For VGA Enabled
Assing IRQ For USB Enabled
PIRQ_0 USE IRQ NO
PIRQ_1 USE IRQ NO
PIRQ_2 USE IRQ NO
PIRQ_3 USE IRQ NO
PCI Health Status
Fan Fail Alarm Selectable Disable
CPU Warning Temp. 120C/248F
ABIT SE-6, перепрошил БИОС, стала твориться мистика...
