BIOS Patcher ver. 6.00.alpha_11. |for Award/Phoenix & AMI bioses| Attention! Advanced qualification is required!
Found 2Mbit AMI BIOS!
!! Module Manipulation Successful !!
4. 32Gb-problem : not found.
Tweak options addinng: for skip this step press "s" or any another key for continue...
if you can`t see all messages - choose 80x50 mode or run with ">report.txt". (c)2002-2004 apple_rom, www.ROM.by (c)2006 Angel07, www.cgi-scripts.info
Мне намекют на то, что никаких проблем с хардом не должно быть?
