Извеняйте думал оповещение по почте прийдёт как на
15 Фев 2004 - 17:19 Unknown BIOS
Извеняйте думал оповещение по почте прийдёт как на OVERA'х,
а вот и лог: BIOS Patcher ver. 4.51.
Found 2Mbit BIOS (6.x)!
Attention! - ASUS BIOS!
Found AMD K7-BIOS/platform!
1. New CPU Support :Can`t find "Unknow"-string for AMD!
Mobile AMD Multipl-r adding :0000 -> fixed.
2. XP frequency :Can`t found frequency!
3. New Koeffs Support : is not needed to be fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : found, but more than one result!
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : Warning! Not found "genu"!
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: not found.
Tweak options addinng:
Bus Disconnect Support : -> fixed.
FID_Enable adding : -> fixed.
Display Features adding : -> fixed.
Creating archive : modul.LZH
==> 22% MODUL.TMP o
Copying TMP to ARCHIVE ... done.
Creating archive : tweak.LZH
==> 65% TWEAK.TMP o
Warning! BootBlock was changed! Flashing BIOS only WITH BootBlock!
(c)2002-2003 apple_rom, www.ROM.by
а вот и лог:
Attention! - ASUS BIOS!![;)](http://bios.rom.by/img/smiles/icon_wink.gif)
==> 22% MODUL.TMP o
==> 65% TWEAK.TMP o
шил своим ASUS'овым прошивальщиком из под винды.
