Вот что показывает MHDD: ID:
Maxtor 5T040H4 LBA:80,043,264 BIOS SN:T4HJ5FGC FW:TAH71DP0 CACHE:2048KB Supports: HPA AAM DLMC LBA MS16 DMA (UDMA5,MWDMA2) SMART: Enabled Size = 39083MB MHDD>ID Maxtor 5T040H4 LBA:80,043,264 BIOS SN:T4HJ5FGC FW:TAH71DP0 CACHE:2048KB Size = 39083MB
HDD: Maxtor 5T040H4; FW: TAH71DP0; SN: TAH71DP0 -------------------------------------------------------- Name Val Worst Raw Att # 1 : Read error rate : 253 252 32 Att # 3 : Spin up time : 207 203 14489 Att # 4 : Number of spin-up times : 252 252 3135 Att # 5 : Reallocated sectors count : 253 230 0 Att # 6 : Read channel margin : 253 253 0 Att # 7 : Seek error rate : 253 249 1 Att # 8 : Seek time performance : 253 246 32919 Att # 9 : Power-on time : 250 250 7458 Att # 10 : Spin-up retries : 253 249 0 Att # 11 : Calibration retries : 253 252 0 Att # 12 : Start/stop count : 248 248 2264 Att # 96 : Unknown : 253 253 0 Att # 97 : Unknown : 253 253 0 Att # 98 : Unknown : 253 253 0 Att # 99 : Unknown : 253 253 0 Att # 100 : Unknown : 253 253 0 Att # 101 : Unknown : 253 253 0 Att # 196 : Reallocate event count : 253 253 0 Att # 197 : Current pending sectors : 253 194 0 Att # 198 : Offline scan UNC sectors : 253 253 0 Att # 199 : Ultra ATA CRC Error Rate : 198 196 3 Att # 200 : Write error rate : 1 1 1928 Att # 201 : Unknown : 253 252 11 Att # 202 : Unknown : 242 242 12 Att # 203 : Unknown : 253 252 42 Att # 204 : Unknown : 253 252 0 Att # 205 : Unknown : 253 252 0 Att # 207 : Unknown : 253 251 0 Att # 208 : Unknown : 253 252 0 Att # 209 : Unknown : 253 253 0
CX:
Init drive: Done Seek&Read Test. Press to finish... Start: 12:33:45 Average Access Time: Read error Maximum: 0.00 ERROR: Seek Test FAILED! Stopping drive... Done: 12:33:46
SCAN: (часть, но так весь винт)
AVG [ 6566 kb/s] Maxtor 5T040H4 LBA:80,043,264 BIOS ACT [ 7082 kb/s] SN:T4HJ5FGC FW:TAH71DP0 CACHE:2048KB Size = 39083MB ░ <3ms : Init drive: Done ▒ <10ms : ▓ <50ms : Scan... █ <150ms: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! █ <500ms: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! █ >500ms: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ? TIME : !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! x UNC : !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ! ABRT : 565 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! S IDNF : !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! A AMNF : !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 0 T0NF : !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! * BBK : !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! [ 0.2% ] [ 0.2% ] Error: 142545 Last scanned LBA: 144329 Error: 142800 Error: 143310 Error: 143565 Error: 143820
Есть еще результаты из программки VCR333, но они по большей части совпадают с этими. SCAN в любом режиме показывает ABRT (не завис. от REMAP, WRITE и тд)
Что скажете ?
ID:
SMART:
HDD: Maxtor 5T040H4; FW: TAH71DP0; SN: TAH71DP0 -------------------------------------------------------- Name Val Worst Raw Att # 1 : Read error rate : 253 252 32 Att # 3 : Spin up time : 207 203 14489 Att # 4 : Number of spin-up times : 252 252 3135 Att # 5 : Reallocated sectors count : 253 230 0 Att # 6 : Read channel margin : 253 253 0 Att # 7 : Seek error rate : 253 249 1 Att # 8 : Seek time performance : 253 246 32919 Att # 9 : Power-on time : 250 250 7458 Att # 10 : Spin-up retries : 253 249 0 Att # 11 : Calibration retries : 253 252 0 Att # 12 : Start/stop count : 248 248 2264 Att # 96 : Unknown : 253 253 0 Att # 97 : Unknown : 253 253 0 Att # 98 : Unknown : 253 253 0 Att # 99 : Unknown : 253 253 0 Att # 100 : Unknown : 253 253 0 Att # 101 : Unknown : 253 253 0 Att # 196 : Reallocate event count : 253 253 0 Att # 197 : Current pending sectors : 253 194 0 Att # 198 : Offline scan UNC sectors : 253 253 0 Att # 199 : Ultra ATA CRC Error Rate : 198 196 3 Att # 200 : Write error rate : 1 1 1928 Att # 201 : Unknown : 253 252 11 Att # 202 : Unknown : 242 242 12 Att # 203 : Unknown : 253 252 42 Att # 204 : Unknown : 253 252 0 Att # 205 : Unknown : 253 252 0 Att # 207 : Unknown : 253 251 0 Att # 208 : Unknown : 253 252 0 Att # 209 : Unknown : 253 253 0CX:
Init drive: Done Seek&Read Test. Press to finish... Start: 12:33:45 Average Access Time: Read error Maximum: 0.00 ERROR: Seek Test FAILED! Stopping drive... Done: 12:33:46SCAN: (часть, но так весь винт)
AVG [ 6566 kb/s] Maxtor 5T040H4 LBA:80,043,264 BIOS ACT [ 7082 kb/s] SN:T4HJ5FGC FW:TAH71DP0 CACHE:2048KB Size = 39083MB ░ <3ms : Init drive: Done ▒ <10ms : ▓ <50ms : Scan... █ <150ms: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! █ <500ms: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! █ >500ms: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ? TIME : !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! x UNC : !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ! ABRT : 565 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! S IDNF : !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! A AMNF : !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 0 T0NF : !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! * BBK : !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! [ 0.2% ] [ 0.2% ] Error: 142545 Last scanned LBA: 144329 Error: 142800 Error: 143310 Error: 143565 Error: 143820Есть еще результаты из программки VCR333, но они по большей части совпадают с этими. SCAN в любом режиме показывает ABRT (не завис. от REMAP, WRITE и тд)
Что скажете ?
