Скачал с Compaq-а диагноастическую дискетку. Выдала в логе:
INSPECT - Version PC10.28A =========================== ---------------------------------------------------------------------------- System : Date: 04/30/2005 Time:12:44:33 Product:Deskpro Machine ID From System Board 400 Processor: Intel(R) Celeron(tm) processor 110 MHz at 1100MHz CPU ID: 068A Numeric Coprocessor: Integrated 387-Compatible Secondary Cache: 128K CPU Mode: Real Mode Current System Speed: High Temperature: Normal Deskpro is a trademark of Compaq Computer Corporation. ---------------------------------------------------------------------------- ROM : System ROM Revision . . . . . . . . . . 08/22/1999 Family . . . . . . . . . . 686T3 Flashable . . . . . . . . . Yes Supports F10 partition . . . Yes Socketed . . . . . . . . . . No Option ROMs Address Range: C0000 - CBBFF
Address Range: E0000 - E7FFF ---------------------------------------------------------------------------- System Storage : Embedded IDE Controller, Base Address 0x170 Device . . . . . . . . . . . . CD-ROM Drive position . . . . . . . . 2 Revision . . . . . . . . . . . 1.0F Model Number . . . . . . . . . TEAC CD-W540E Diskette Drive A . . . . . . . . 1.44 Megabyte (3.5 inch) Drive Controller 1 Standard Interface . . . . . . Primary Hard Drive 1 . . . . . . . . . Type 1 Serial Number . . . . . . . . 3HSADJ42 Firmware Revision 1 . . . . . 3.19 Model Number . . . . . . . . . ST340016A IntelliSafe Hard Drive Status. OK ---------------------------------------------------------------------------- Memory : Memory Boards Identified: System Board DIMM Slot 1 . . . . . . . . 0 Megabytes DIMM Slot 2 . . . . . . . . 0 Megabytes DIMM Slot 3 (SDRAM) . . . . 256 Megabytes Compaq Header Not Programmed
Memory Allocation (including INSPECT) PSP SIZE NAME TRAPPED INTERRUPTS ---- ------ ------------ -------------------------------------- 0E28 002192 COMMAND.COM 22h 2980 329120 INSPECT.EXE 24h 3Fh 00h 1003 104384 48h 30h 10h
---------------------------------------------------------------------------- Miscellaneous :
System Configuration Memory 00 - 0F : 15 53 45 08 12 00 06 30 04 05 26 82 50 80 00 00 10 - 1F : 40 00 10 20 03 80 02 00 FC 01 00 00 00 F0 00 05 20 - 2F : 00 00 00 00 7E 2B 40 40 00 9E 02 23 00 00 04 D3 30 - 3F : 00 FC 20 80 00 21 XX XX XX XX XX XX XX XX XX XX
BIOS Data Area 40:0000 : F8 03 F8 02 00 00 00 00 78 03 00 00 00 00 C0 9F 40:0010 : 27 44 00 7F 02 9C 00 00 00 00 20 00 20 00 0D 1C 40:0020 : 6F 18 6D 32 70 19 61 1E 71 10 0D 1C 0D 1C E0 50 40:0030 : E0 50 E0 48 E0 48 E0 50 E0 50 E0 50 E0 48 01 01 40:0040 : 25 00 04 00 00 2F 01 05 02 12 50 00 00 A0 00 00 40:0050 : 00 21 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40:0060 : 00 00 00 D4 03 29 30 14 05 57 8F 00 A2 BA 0C 00 40:0070 : 00 00 00 12 00 01 08 03 14 14 14 14 01 01 01 01 40:0080 : 1E 00 3E 00 1D 10 00 60 09 11 0B 01 50 00 00 05 40:0090 : 17 00 00 00 2F 00 10 00 00 00 00 00 00 00 00 00 40:00A0 : 00 00 00 00 00 00 00 00 41 A8 00 C0 00 00 00 00 40:00B0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40:00C0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40:00D0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40:00E0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40:00F0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Interrupt Vector Table (including INSPECT) 00 - 03 : 2990:0555 0070:06F4 0DB3:0016 0070:06F4 04 - 07 : 0070:06F4 F000:FF54 F000:93CC F000:9BD0 08 - 0B : 0DB3:003C 0DB3:0045 F000:9BD0 F000:9BD0 0C - 0F : F000:9BD0 F000:9BD0 0DB3:00B7 0070:06F4 10 - 13 : 1312:34CE F000:F84D F000:F841 0070:0774 14 - 17 : F000:E739 0070:084A F000:E82E F000:EFD2 18 - 1B : F000:1C86 0070:07FB F000:FE6E 0070:06EE 1C - 1F : F000:FF53 F000:F0A4 0000:0522 C000:83D0 20 - 23 : 0010:40DC 0010:4108 0E28:04A9 0010:40E2 24 - 27 : 8F57:43FA 0010:42F5 0010:437C 0010:A1DD 28 - 2B : 0010:40E2 0070:0762 0010:40E2 0010:40E2 2C - 2F : 0010:40E2 0010:40E2 0010:40E2 0010:44CD 30 - 33 : 1040:E3EA F000:9B00 0010:40E2 0010:40E2 34 - 37 : 0010:40E2 0010:40E2 0010:40E2 0010:40E2 38 - 3B : 0010:40E2 0010:40E2 0010:40E2 0010:40E2 3C - 3F : 0010:40E2 0010:40E2 0010:40E2 3AE5:04FD 40 - 43 : F000:B722 F000:E401 F000:F065 C000:95D0 44 - 47 : F000:9BD0 F000:9BD0 F000:E401 F000:9BD0 48 - 4B : 1013:00F3 F000:9BD0 F000:9BD0 F000:9BD0 4C - 4F : F000:9BD0 F000:9BD0 F000:9BD0 F000:9BD0 50 - 53 : F000:9BD0 F000:9BD0 F000:9BD0 F000:9BD0 54 - 57 : F000:9BD0 F000:9BD0 F000:9BD0 F000:9BD0 58 - 5B : F000:9BD0 F000:9BD0 F000:9BD0 F000:9BD0 5C - 5F : F000:9BD0 F000:9BD0 F000:9BD0 F000:9BD0 60 - 63 : 0000:0000 0000:0000 0000:0000 0000:0000 64 - 67 : 0000:0000 0000:0000 0000:0000 0000:0000 68 - 6B : F000:9BD0 F000:9BD0 F000:9BD0 F000:9BD0 6C - 6F : F000:9BD0 C000:2B62 F000:9BD0 F000:9BD0 70 - 73 : 0DB3:0052 F000:9C1F F000:9BD0 F000:9BD0 74 - 77 : 0DB3:00FF F000:9C28 0DB3:0117 0DB3:012F 78 - 7B : 0000:0000 0000:0000 0000:0000 0000:0000 7C - 7F : 0000:0000 0000:0000 0000:0000 0000:0000 80 - 83 : 0000:0000 0000:0000 0000:0000 0000:0000 84 - 87 : 0000:0000 0000:0000 0000:0000 0000:0000 88 - 8B : 0000:0000 0000:0000 0000:0000 0000:0000 8C - 8F : 0000:0000 0000:0000 0000:0000 0000:0000 90 - 93 : 0000:0000 0000:0000 0000:0000 0000:0000 94 - 97 : 0000:0000 0000:0000 0000:0000 0000:0000 98 - 9B : 0000:0000 0000:0000 0000:0000 0000:0000 9C - 9F : 0000:0000 0000:0000 0000:0000 0000:0000 A0 - A3 : 0000:0000 0000:0000 0000:0000 0000:0000 A4 - A7 : 0000:0000 0000:0000 0000:0000 0000:0000 A8 - AB : 0000:0000 0000:0000 0000:0000 0000:0000 AC - AF : 0000:0000 0000:0000 0000:0000 0000:0000 B0 - B3 : 0000:0000 0000:0000 0000:0000 0000:0000 B4 - B7 : 0000:0000 0000:0000 0000:0000 0000:0000 B8 - BB : 0000:0000 0000:0000 0000:0000 0000:0000 BC - BF : 0000:0000 0000:0000 0000:0000 0000:0000 C0 - C3 : 0000:0000 0000:0000 0000:0000 0000:0000 C4 - C7 : 0000:0000 0000:0000 0000:0000 0000:0000 C8 - CB : 0000:0000 0000:0000 0000:0000 0000:0000 CC - CF : 0000:0000 0000:0000 0000:0000 0000:0000 D0 - D3 : 0000:0000 0000:0000 0000:0000 0000:0000 D4 - D7 : 0000:0000 0000:0000 0000:0000 0000:0000 D8 - DB : 0000:0000 0000:0000 0000:0000 0000:0000 DC - DF : 0000:0000 0000:0000 0000:0000 0000:0000 E0 - E3 : 0000:0000 0000:0000 0000:0000 0000:0000 E4 - E7 : 0000:0000 0000:0000 0000:0000 0000:0000 E8 - EB : 0000:0000 0000:0000 0000:0000 0000:0000 EC - EF : 0000:0000 0000:0000 0000:0000 0000:0000 F0 - F3 : 0000:0000 0000:0000 0000:0000 0000:0000 F4 - F7 : 0000:0000 0000:0000 0000:0000 0000:0000 F8 - FB : 0000:0000 0000:0000 0000:0000 0000:0000 FC - FF : 0000:0000 0000:0000 0000:0000 0000:0000
По сути дела все вроде впорядке, только что название процессора не такое, так спрашивается почему он пишет: 918-This system does not support the current processor.
Выдала в логе:
System :
Date: 04/30/2005
Time:12:44:33
Product:Deskpro
Machine ID
CPU ID: 068A
CPU Mode: Real Mode
Temperature: Normal
ROM :
System ROM
Option ROMs
System Storage :
Drive Controller 1
Memory :
System Board
System Unit Serial Number Not Programmed
Module ID 255
Total Compaq Memory . . . . . . 256 Megabytes
Base Memory
System Total . . . . . . . . . 639 Kbytes
Amount Free . . . . . . . . . 580 Kbytes (594144 Bytes)
Extended Memory
System Total . . . . . . . . . 261120 Kbytes
Expanded Memory
LIM Driver Support . . . . . . LIM driver not loaded
Miscellaneous :
BIOS Data Area
