Ограничение тока это, резистор на землю кидается, если ничего не прикручивать то будет ограничен как в описании
Peak Current Limit. This pin adjusts the peak current limit of the SenseFET.
The 0.9mA feedback current source is diverted to the parallel combination of
an internal 2.8kΩ resistor and any external resistor to GND on this pin. This
determines the peak current limit. If this pin is tied to VCC or left floating, the
typical peak current limit is 0.8A (FSQ0170RNA), 0.9A (FSQ0270RNA), or
1.1A (FSQ0370RNA).
