Так говорит AMD по поводу своей памяти: Flash memory
Flash memory devices in FBGA packages may be
damaged if exposed to ultrasonic cleaning methods
еще в Toshiba
(toshiba.com/taec/components/docs/Generic/neuron/2.pdf):
Ultrasonic cleaning should not be used with hermetically-sealed ceramic packages such as a leadless chip carrier (LCC), pin grid array (PGA) or charge-coupled device (CCD), because the bonding wires can become disconnected due to resonance during the cleaning process. Even if a device package allows ultrasonic cleaning, limit the duration of ultrasonic cleaning to as short a time as possible,
Организация сервис-центра по ремонту
