Пытаюсь восстановить TP-Link WR1043ND. После включения на секунду
После включения на секунду загораются все светодиоды и гаснут. Остаётся только питание
PuTTY выдаёт следующее:
U-Boot 1.1.4 (Nov 2 2012 - 14:04:55)
AP83 (ar9100) U-boot 0.0.11
DRAM:
sri
32 MB
id read 0x100000ff
flash size 8MB, sector count = 128
Flash: 8 MB
Using default environment
In: serial
Out: serial
Err: serial
Net: ag7100_enet_initialize...
No valid address in Flash. Using fixed address
: cfg1 0xf cfg2 0x7114
eth0: xx:xx:xx:xx:xx:xx
eth0 up
eth0
Autobooting in 1 seconds## Booting image at bf020000 ...
Uncompressing Kernel Image ... OK
Starting kernel ...
Linux version 2.6.39.4 (pilot6@debian) (gcc version 4.5.4 20110808 (prerelease) (Linaro GCC 4.5-2011.08) ) #1 Tue Nov 15 15:39:32 EST 2011
bootconsole [early0] enabled
CPU revision is: 00019374 (MIPS 24Kc)
SoC: Atheros AR9132 rev 2
Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:5.000MHz
Determined physical RAM map:
memory: 02000000 @ 00000000 (usable)
Initrd not found or empty - disabling initrd
Zone PFN ranges:
Normal 0x00000000 -> 0x00002000
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0x00000000 -> 0x00002000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
Kernel command line: board=TL-WR1043ND console=ttyS0,115200 rootfstype=squashfs,jffs2 noinitrd
PID hash table entries: 128 (order: -3, 512 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Writing ErrCtl register=00000000
Readback ErrCtl register=00000000
Memory: 29360k/32768k available (2021k kernel code, 3408k reserved, 390k data, 180k init, 0k highmem)
SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:80
Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
NET: Registered protocol family 16
MIPS: machine is TP-LINK TL-WR1043ND
bio: create slab at 0
Switching to clocksource MIPS
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
squashfs: version 4.0 (2009/01/31) Phillip Lougher
JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
msgmni has been set to 57
io scheduler noop registered
io scheduler deadline registered (default)
Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11) is a 16550A
console [ttyS0] enabled, bootconsole disabled
Atheros AR71xx SPI Controller driver version 0.2.4
m25p80 spi0.0: unrecognized JEDEC id 1c3017
Realtek RTL8366RB ethernet switch driver version 0.2.3
rtl8366rb rtl8366rb: using GPIO pins 18 (SDA) and 19 (SCK)
rtl8366rb rtl8366rb: RTL5937 ver. 3 chip found
rtl8366rb: probed
eth0: Atheros AG71xx at 0xb9000000, irq 4
Atheros AR71xx hardware watchdog driver version 0.1.0
TCP westwood registered
NET: Registered protocol family 17
802.1Q VLAN Support v1.8 Ben Greear
All bugs added by David S. Miller
VFS: Cannot open root device "(null)" or unknown-block(0,0)
Please append a correct "root=" boot option; here are the available partitions:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
Команды в PuTTY не пишутся.
Что дальше?
[Решено] Не выходит восстановить прошивку роутера TP-Link TL-WR1043ND
  • Если это не получается Включите роутер Когда в окне
  • Загрузчик у вас живой. Почитайте тут, раздел "Прошивка с
  • похожая проблема - при включении горит Power, но
  • Удалось прошить флэшку. Использовался программатор на резисторах LPT порт. Для
  • Deviator если будут вопросы, то обращусь.
  • kuchka94 давай так deviator.83@mail.ru быстрее будет.
  • она самая. по команде spipgmw /l посмотри что
  • Deviator Вскрыл роутер, оказалось чип FL064PIF от Spansion. Я
  • все правильно. номиналы сопротивлений желательно как можно ближе
  • Deviator Вроде разобрался, посмотрите, проверьте пожалуйста.
  • Deviator а какие выводы лпт паять к ногам 7,
  • kuchka94 Я делал схему на LPT, так как просто
  • Deviator можете дать сылки на необходимую информацию, как сделать
  • kuchka94 У меня подобные симптомы былы когда залил
  • Здравствуйте, помогите решить проблему. Роутер Tp-Link WR1043ND. Когда
  • Держите кто просил. Полный дамп S25FL064 от TL-WR1043ND -
  • Скорость обмена точно правильно выставлена? Попробуйте менять.
  • Добрый день. Я по незнанию очистил rootfs, пытаюсь
  • Помогите кто чем сможет. Имею только переходник USB-RS232.
  • Купил 2 железяки 1043. Одну настроил и поставил
  • Убил свою железку. :( Через serial тишина. Парни, кто
  • так может кто поделится дампом??
  • Что в терминале? Для того, чтобы связаться
  • я ради дампа флешки одному кадру заплатил 20
  • можно пробовать запускать под окнами в
  • Я бы не советовал - через резисторы на
  • я имел ввиду как раз не через мать,
  • Вполне возможно. Что Erace необходим. Но все нужно
  • у меня программатор Uniprog, к сожалению он не
  • Я догадываюсь, что там с загрузчиком проблема. А
  • вы затерли загрузчик, поэтому естественно нет загрузки. Появился в
  • на заборе тоже написано... Флешка: S25FL064. У меня
  • может и так, по крайней мере на ней
  • может все-таки S25FL064?
  • народ кто шил флеш FL064PIF ?? чтоза зверь?
