Hello! Thank You for Your reply. I have solved
Hello!
Thank You for Your reply. I have solved it in a little complicated way. I've extracted microcodes form AMI BIOS, after that I've took any AWARD Bios and removed microcodes module from it and last I've appended my AMI extracted microcdes module to Award module. Cbrom has listed added CPU support microcodes without problem.
PROBLEM SOLVED! P
Regards.
