Сообщение выдано на консоль (не в файл, который привожу ниже) после обработки AWARD 2a59gl1c
Файл отчета патчера:
BIOS Patcher ver. 4.51.
Found 1Mbit BIOS!
BIOS-PartName Segm:Offs Compress/Real_Size "Official" name - what`s meanining
original.tmp 5000:0000 0001:1F8F/0002:0000 "original.tmp" - MAIN partSearch start.modul:
1. New CPU Support : not found.
2. P3-detect error : not found.
3. New Koeffs Support : not found.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : not found.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : Warning! Not found "genu"!
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: not found.
UDMA66/100/133 on UDMA33_only_MB patch: not found.
Tweak options addinng:
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 13.3%
Adding tweak.tmp 69.5%
Adding start.tmp 87.5%
Adding cpucode.bin 55.9%
(c)2002-2003 apple_rom, www.ROM.by
Found 1Mbit BIOS!
Что можно сказать ?
Или дайте ссылку.
