Don t worry, your English is good enough.
Don't worry, your English is good enough. And it can be understood much easier than computer translations to Russian, used by some people ;)
Well, first of all, you can try version 4.23 of patcher. You will need these files also:
cbrom.exe
lha.exe
reall.cod
amibcp.exe
You can try even v6 alpha 10 - but only if you have an opportunity to reflash BIOS somewhere else in case of errors. Just because it is completely rewritten alpha version and it is not giving stable results everywhere.
Also, it will be a good idea to post here the patching log.
