I don't mean that I can't redirect the stream, but it is nothing special to include I think. I patch using manual switch /m becouse I like to do what I really need / want. You could add \l log_file_name option to command line supporting write to log becouse I had to generate this pressing keys from "memory" like blind man)
Log below
BIOS Patcher ver. 4.51.
Found 1Mbit BIOS!
1. New CPU Support for skip this step press "s" or any another key for continue...
-> fixed.
2. P3-detect error for skip this step press "s" or any another key for continue...s
3. New Koeffs Support >for skip this step press "s" or any another key for continue...
-> fixed.
4. 32Gb-problem not found.
5. Some HDD detect-problem not found.
6. "MB"/"GB" string search is not needed to be fixed.
9. Error display Freq>999MHz not found.
10.Error display Koefs>9.5x not found.
11.New Stepping Support is not needed to be fixed.
12.Tualatin L2-init error not found.
13.New Freq in Setup open not found.
14.Set "Y" as default on exitfor skip this step press "s" or any another key for continue...s
UDMA66/100/133 on UDMA33_only_MB patch not found.
Tweak options addinng
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
[CPUCODE] ROM is releaseCBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 27.5%
Adding tweak.tmp 0.0%
Adding start.tmp 87.5%
Adding cpucode.bin 53.6%
(c)2002-2003 apple_rom, www.ROM.by
Log below
Found 1Mbit BIOS!
-> fixed.
-> fixed.
