Скриншоты приводить не буду, так как не у всех инет на халяву (у меня в том числе). Но суть я думаю все поймут.
Trend ChipAwayVirus has detected a boot virus on your hard
disk. The operating system is not supported by ChipAwayVirus.
Press for more information (recommended)
to continue booting
"Complete Virus Protection for the Enterprise"
Trend Micro - antivirus.com
Жму Enter
To prevent the data lost from your computer,
Trend ChipAwayVirus will restart your system.
Insert a bootable clean floppy disk into your floppy driver
press to restart your system
to go back to previous screen
For more information on Viruses, visit www.antivirus.com
Жму B, потом C.
If you continue to boot up your system, the virus will
be left in your computer.
Are you sure you want to continue the boot up procedure?
Press to continue the boot anyway.
to return to previous screen.
For more informatoin on viruses, visit www.antivirus.com
Кстати, я починил купленную за 70р на molotok.ru плату A-Trend ATC-6240 (плата на i440,надо было пару конденсаторов заменить). Эта плата никакого бут вируса не находит. Проблема в ромбайской прошивке?
Trend ChipAwayVirus has detected a boot virus on your hard disk. The operating system is not supported by ChipAwayVirus. Press for more information (recommended) to continue booting "Complete Virus Protection for the Enterprise" Trend Micro - antivirus.comЖму Enter
To prevent the data lost from your computer, Trend ChipAwayVirus will restart your system. Insert a bootable clean floppy disk into your floppy driver press to restart your system to go back to previous screen For more information on Viruses, visit www.antivirus.comЖму B, потом C.
If you continue to boot up your system, the virus will be left in your computer. Are you sure you want to continue the boot up procedure? Press to continue the boot anyway. to return to previous screen. For more informatoin on viruses, visit www.antivirus.comКстати, я починил купленную за 70р на molotok.ru плату A-Trend ATC-6240 (плата на i440,надо было пару конденсаторов заменить). Эта плата никакого бут вируса не находит. Проблема в ромбайской прошивке?
