Натолкнулся в инете на фразу:
If your only problem
26 Июл 2004 - 12:37 Unknown BIOS
If your only problem is not being able to add a HD over 2 GIG, get a copy of "Disk-Wizard" or another program like it.
It will have you enter your disk size in your BIOS @: 1024 cyl, 16 heads, 63 sectors. Then it will install a DDE into your boot sector and alow your computer to use the whole disk. I am currently using a 9.1 GIG on a '93 BIOS.
О каком софте речь? Никто не сталкивался?
Кстати - загрузил еще немного AMI бивисов на чипсет 82439HX
BP ни один не "Взял"
