current BIOS 1.06:
Solved Problems:
- none
Known Problems:
- When updating the BIOS from 1.05c to 1.06c with a TJ85 CPU inserted, the CPU
frequency will be shown as 600MHz (within BIOS setup) until the default settings
are loaded and the system is rebooted. This is due to the BIOS 1.05cl does not
have the implementation for TJ85 CPUs.
Сбросте биос на Default Settings.
current BIOS 1.06:
Solved Problems:
- none
Known Problems:
