Автор: Jega , 23 января 2009
At first start POST card said FF. All voltages (CPU, RAM, AGP, SB, NB...) OK!
I tried to take original EPROM from this MOBO and put him into MSI TL-46 POST card who can bybass MOBO BIOS and boot from external eprom.
MOBO start normaly!?
I desoldered eprom socket and soldered eprom directly to PCB.
POST FF again!
How to find what is preventing MOBO BIOS to laoad and alowes loading external BIOS?
p.s. I changet IT8705F, heated South and north, changed battery.
_an_
17 лет 9 месяцев назад
Посмотрите куда идут линии данных с микросхемы BIOS на материнской плате
Jega
Here is the result of measurement of MOBO eprom:
- VDD= 5.3V
- RESET =5.3V
- #CE= 0V
- #OE =5.3V
- A0-A9 =5.3V; A10,A11 =0V ; A12-A17 =5.3V
- DQ0-DQ7 =0.9V
As I read in datasheet (in attachment) for W49F002U when #OE (output enable) is in High logic level (Vih) output is disabled. I don`t have enough expirience with this cind of problems and this is just common sence conclusion: If chip have disabled output how do I enable it? I tried to track where is it going and find nothing.
What about A11 and A12? Is it normal to all other adress imputs have 5.3V and they 0V?
Usually present a pullup resistor (or resistor array). This pin connected to south bridge or MIO. MIO marking, please.
And result of measurement of pins #WE.
