private message to MmM send. In the leeme.txt I
In the leeme.txt I put the following thing:
*On English
This bios allows that a Celeron 1400 Fsb 100 L2 256 kbytes Core Tualatin should work perfectly and of stable form on a motherboard Gigabyte GA-6ZXC Rev 2.0, motherboard that it takes a chipset Zx and is Slot 1. First I tried to create it to hand using the microcodes of a badge Gigabyte more advanced and that if he was supporting Tualatin Celeron 1.4. But it had problems of Checksum error that I was unable to correct. Then utilizй the patch of www.rom.by and once I recorded the bios, the error of checksum bios error was happening. Finally I decided to use a private program that we use in Spain some peoples of "Tv Educatica" to correct checksums, and ..? eureka!, it worked perfectly.
To indicate that I had problems at the beginnig of Bios Cheksum Error, which are already corrected.
To give them thanks to www.biosmods.com and www.rom.by with his spectacular patch, for all the work that they have realized to allow that things like this one should be made a reality. Although I recommend to them care, because in my case he had to perfect the changes that does the patch so that it me was working and was not giving me the errors of Bios Checksum Error.
A Greeting
Ah!!!! Now I have the fixed thorn of a Supermike P6SDbe Rev 3.0 Dual motherboard. A Celeron Coppermine 1000 Mhz 128 kbytes Socket 370 works perfectly stablly in this one with Powerleap Pl-ip3/T Rev 2.
The Celeron 1400 Tualatin starts there is seen the bios of the graphic card and there it remains idle. With a modified bios I am sure that it would work, but it is an Amibios.... His sister the P6Sba works with a bios modified by someone so-called Eugene Hsieh. I have not found any decent program that allows me to modify the code of the bios or to extract the microcodes as if it happens in Bios Award.. Do you know anything about advances in this sense for the Amibios?. Thank you and a greeting. (He excuses for my English......).
A Greetings
