>bp-4_23 vvvvvvvv.bin
1. New CPU Support : -> fixed
2. P3-detect error : -> is not needed to be fixed
3. New Koeffs Support: -> fixed
4. 32Gb-problem : not found
5.Some HDD detect-problem :not found
6. "MB"/"GB" string search: -> is not needed to be fixed
9. Error display Freq>999MHz: -> is not needed to be fixed
10.Error display Koefs>9.5x:not found
11. New Stepping Support: -> is not needed to be fixed
12.Tualatin L2-init error :not found
13.New Freq in Setup open:not found
14.Set "Y" as default on exit:->fixed
Write allocate addinng: not found
UDMA for "big"-HDD on UDMA_only_MB fix: not found
Adding modul.tmp 24.2%
Adding start.tmp 87.5%
