Автор: ROMby Unknown , 16 апреля 2007
I've made short cirquit on the cpu-fan header on that motherboard.
As result the chip under the cpu-fan header in package SOT428 / DPAK has splited in pieces.
So I don't know whether it was a transistor or an IC.
Please anyone who has such MB to check the marking and post it here.
Thanks in advance!
p.s. I'm newbie to this forum and also I want to ask for rever to a schematic of USB ESD protection for ICH5 and above.
Root
19 лет 3 месяца назад
pls, post here the positional number of element (such as Q512 or U43)
Unknown BIOS (не проверено)
It is P-channel AP3310H with marking "3310H" made by "Advanced Power Electronics Corp."
http://www.a-power.com.tw/pdf/Datasheet/AP3310H.pdf
As far as I can see corectly its position on the MB's PCB is Q93, but this is not important any more.
Its function is a buffer drive between na PWM and the CPU-FAN.
http://www.uac.co.jp/news/daily/040305/p4p800se_l2.jpg
Now I should buy a suitable match and replace the poor remains of the old AP3310H.
Edit: Был успешно заменён на IRFR5305 http://www.irf.com/product-info/datasheets/data/irfr5305.pdf. Все работает в полном порядке.
