<!--break-->
SMI:0000 ; ===========================================================================
SMI:0000
SMI:0000 ; Segment type: Pure code
SMI:0000 SMI segment byte public 'CODE' use16
SMI:0000 assume cs:SMI
SMI:0000 assume es:nothing, ss:nothing, ds:nothing, fs:nothing, gs:nothing
SMI:0000 SMI_GDT dw 97h ; LIMIT
SMI:0002 dw offset GDT0
SMI:0004 dw 0
SMI:0006 ; align
SMI:0008 GDT0 DESCRIPTOR <0> ; DATA XREF: SMI:0002
SMI:0010
SMI:0010 DESCRIPTOR <0FFFFh, 0, 0DAh, 9Ah, 0, 0FEh> ; FEDA000:0, code_seg
SMI:0018 DEF_desc_smi DESCRIPTOR <0FFFFh, 0, 0DAh, 92h, 0, 0FEh>
SMI:0018 ; DATA XREF: sub_A2F26+4
SMI:0018 ; SMI_Handler:next ...
SMI:0018 ; FEDA000:0
SMI:0020 stru_A0020 DESCRIPTOR <0FFFFh, 0, 0DAh, 92h, 0, 0FEh> ; DATA XREF: sub_AA7C6
SMI:0020 ; FEDA000:0
SMI:0028
SMI:0028 all_mem_seg DESCRIPTOR <0FFFFh, 0, 0, 92h, 0CFh, 0>
SMI:0028 ; DATA XREF: TurnOff_Power+75
SMI:0028 ; Trap_Handler+5 ...
SMI:0028 ; 0:0
SMI:0030 DESCRIPTOR <0FFFFh, 0, 0, 92h, 0, 0> ; 0:0
SMI:0038 DESCRIPTOR < 4FFh, 0, 0, 92h, 0, 0> ; 0:0 - 0:500
SMI:0040
SMI:0040 BDA_seg DESCRIPTOR < 0FFh, 400h, 0, 92h, 0, 0>
SMI:0040 ; DATA XREF: USB_SMI+1B1
SMI:0040 ; 40:0 - 40:FF
SMI:0048
SMI:0048 DESCRIPTOR <0FFFFh, 0, 0Eh, 9Ah, 0, 0> ; E000:0, code_seg
SMI:0050 DESCRIPTOR <0FFFFh, 0, 0Eh, 92h, 0, 0> ; E000:0
SMI:0058 DESCRIPTOR <0FFFFh, 0, 0Bh, 92h, 0, 0> ; B000:0
SMI:0060 F000_seg_CODE DESCRIPTOR <0FFFFh, 0, 0Fh, 9Ah, 0, 0>
SMI:0060 ; DATA XREF: Software_SMI_Handler+98
SMI:0060 ; Enable_PME_Event+26 ...
SMI:0060 ; F000:0, code_seg
SMI:0068 F000_seg DESCRIPTOR <0FFFFh, 0, 0Fh, 92h, 0, 0>
SMI:0068 ; DATA XREF: Check_USB_Disabled+1
SMI:0068 ; Get_USBRAM_+1 ...
SMI:0068 ; F000:0
SMI:0070 PM_RAM_seg DESCRIPTOR < 90h, 0DF70h, 0Fh, 92h, 0, 0>
SMI:0070 ; DATA XREF: SMI_Handler+61
SMI:0070 ; SMI_Load_Timer+3 ...
SMI:0070 ; F000:DF70
SMI:0078 SS_GDT_SMI DESCRIPTOR <0FFFFh, 0, 0Ah, 92h, 0, 0>
SMI:0078 ; DATA XREF: SMI_Handler+4E
SMI:0078 ; A000:0
SMI:0080 USB_RAM DESCRIPTOR < 7000h, 8000h, 0Ch, 92h, 0, 0>
SMI:0080 ; DATA XREF: Get_USBRAM
SMI:0080 ; C800:0
SMI:0088 stru_A0088 DESCRIPTOR <0FFFFh, 8000h, 0Ah, 92h, 0, 0>
SMI:0088 ; DATA XREF: SMI:stru_A8FB3
SMI:0088 ; FlashSMI+3B ...
SMI:0088 ; A800:0
SMI:0090 stru_A0090 DESCRIPTOR <0FFFFh, 9000h, 0Ah, 92h, 0, 0>
SMI:0090 ; DATA XREF: SMI:8FB7
SMI:0090 ; FlashSMI+44 ...
SMI:0090 ; A900:0
SMI:0098 stru_A0098 DESCRIPTOR <0FFFFh, 0A000h, 0Ah, 92h, 0, 0>
SMI:0098 ; DATA XREF: SMI:8FBB
SMI:0098 ; FlashSMI+4D ...
SMI:0098 ; AA00:0
SMI:8000 ; --------------- S U B R O U T I N E ---------------------------------------
SMI:8000
SMI:8000
SMI:8000 SMI_Handler proc near
SMI:8000 mov al, 0C0h ; 'L'
SMI:8002 out 70h, al ; CMOS Memory:
SMI:8002 ;
SMI:8004 out 0EBh, al
SMI:8006 in al, 71h ; CMOS Memory
SMI:8008 and al, 2
SMI:800A jnz short loc_A800E
SMI:800C wbinvd
SMI:800E
SMI:800E loc_A800E: ; CODE XREF: SMI_Handler+A
SMI:800E mov al, 0A5h ; 'a'
SMI:8010 out 0B3h, al ; Interrupt Controller #2, 8259A
SMI:8012 mov ax, 0F000h
SMI:8015 mov es, ax
SMI:8017 assume es:nothing
SMI:8017 mov si, offset REAL_IDT_LOC
SMI:801A lidt qword ptr es:[si]
SMI:801E xor ax, ax
SMI:8020 mov ds, ax
SMI:8022 mov ebx, 0
SMI:8028 db 66h
SMI:8028 lgdt qword ptr cs:[ebx]
SMI:802E mov eax, cr0
SMI:8031 and eax, 9FFFFFFFh
SMI:8037 or eax, 1
SMI:803B mov cr0, eax
SMI:803B ; ---------------------------------------------------------------------------
SMI:803E SMI_seg <0EAh, offset next, 8> ; SMI_GDT
SMI:8043 ; ---------------------------------------------------------------------------
SMI:8043
SMI:8043 next: ; DATA XREF: SMI_Handler+3E
SMI:8043 mov ax, (offset DEF_desc_smi-8) ; SMI_GDT
SMI:8046 mov ds, ax
SMI:8048 assume ds:nothing
SMI:8048 mov es, ax
SMI:804A assume es:nothing
SMI:804A mov fs, ax
SMI:804C assume fs:nothing
SMI:804C mov gs, ax
SMI:804E assume gs:nothing
SMI:804E mov ax, (offset SS_GDT_SMI-8) ; A000:0
SMI:8051 mov ss, ax
SMI:8053 assume ss:nothing
SMI:8053 mov esp, offset unk_AF800 ; Stack_SMI__ESP
SMI:8059 pushad
SMI:805B push ds
SMI:805C push es
SMI:805D push fs
SMI:805F push gs
SMI:8061 mov ax, (offset PM_RAM_seg-8) ; F000:DF70
SMI:8064 mov ds, ax
SMI:8066 assume ds:nothing
SMI:8066 cmp byte ptr ds:1Dh, 41h ; 'A' ; Software_SMI_Type:
SMI:8066 ; SMI_0V_Resume EQU 5 ;Resume From 0V
SMI:8066 ; SMI_BIOS_RSM EQU 6 ;Made real mode RSM
SMI:8066 ; SMI_5V_Resume EQU 7 ;R23
SMI:8066 ; SMI_S4_Resume EQU 8 ;R36
SMI:8066 ; DISABLE_RESUME_RING EQU 10h
SMI:8066 ; ENABLE_RESUME_RING EQU 11h
SMI:8066 ; DISABLE_TIMER_REQ EQU 12h
SMI:8066 ; ENABLE_TIMER_REQ EQU 13h
SMI:8066 ; RESTORE_POWERON_D4_REQ EQU 14h
SMI:8066 ; DISABLE_PM_REQ EQU 15h
SMI:8066 ; ENABLE_PM_REQ EQU 16h
SMI:8066 ; CRT_OFF_REQ EQU 17h
SMI:8066 ; CRT_ON_REQ EQU 18h
SMI:8066 ; DISABLE_RESUME_TIMER_REQ EQU 19h
SMI:8066 ; ENABLE_RESUME_TIMER_REQ EQU 1Ah
SMI:8066 ; SMI_SMB EQU 20h ; handle smart bus command
SMI:8066 ;
SMI:8066 ; SMI_FlashRead EQU 28h
SMI:8066 ; ...
SMI:8066 ; SMI_Auto_Flash EQU 2Fh
SMI:8066 ;
SMI:8066 ; APM_SMI EQU 30h
SMI:8066 ; S2_RESTORE_REQ EQU 40h
SMI:8066 ; S3_RESTORE_REQ EQU 41h
SMI:806B jz short S3_RESTORE
SMI:806D mov dx, 0CF8h
SMI:8070 in eax, dx
SMI:8072 push eax
SMI:8074 push dx
SMI:8075 call USB_SMI
SMI:8078 pop dx
SMI:8079 pop eax
SMI:807B out dx, eax
SMI:807D
SMI:807D S3_RESTORE: ; CODE XREF: SMI_Handler+6B
SMI:807D pop gs
SMI:807F assume gs:nothing
SMI:807F pop fs
SMI:8081 assume fs:nothing
SMI:8081 pop es
SMI:8082 assume es:nothing
SMI:8082 pop ds
SMI:8083 assume ds:nothing
SMI:8083 popad
SMI:8085 mov dx, 0CF8h
SMI:8088 in eax, dx
SMI:808A push eax
SMI:808C push dx
SMI:808D call Shadow_WE__mb
SMI:8090 call Run_Handler
SMI:8093 call Shadow_RO__mb
SMI:8096 pop dx
SMI:8097 pop eax
SMI:8099 out dx, eax
SMI:809B call sub_AA01C
SMI:809E mov ax, (offset DEF_desc_smi-8) ; FEDA000:0
SMI:80A1 mov ds, ax
SMI:80A3 assume ds:nothing
SMI:80A3 call nullsub_52
SMI:80A6 mov al, 0C0h ; 'L'
SMI:80A8 out 70h, al ; CMOS Memory:
SMI:80A8 ;
SMI:80AA out 0EBh, al
SMI:80AC in al, 71h ; CMOS Memory
SMI:80AE and al, 2
SMI:80B0 jnz short exit
SMI:80B2 wbinvd
SMI:80B4
SMI:80B4 exit: ; CODE XREF: SMI_Handler+B0
SMI:80B4 rsm
SMI:80B4 SMI_Handler endp
