Автор: NMD , 10 ноября 2007
Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
egor-land
12 лет 12 месяцев назад
Нет разницы какими выводами соединены между собой защитные стабилитроны в затворе полевика.
Анодами или катодами , главное чтобы встречно.
Суть их от этого не меняется.
Step
12 лет 11 месяцев назад
Погорели силовики D4515 с обвязкой и шимом, поменял на 13009, БП заводится, работает, но не долго, перегреваются силовики, читал, что надо ток базы подбирать, это резистор который непосредственно в базу? который 1 Ом или который 39 Ом, последовательно с диодом и конденсатором паралельно?
Резисторы никогда не подбирал. Замените рядом с ними конденсаторы.
Step
дело в том, что резисторы погорели и что там стояло не могу знать, поставил как на схеме из инета, а в разных схемах стоят от 1мкф, до 10мкф, как ёмкость влияет на ток базы? какую ёмкость ставить, что бы ток базы был меньше?
4,7
remonter
12 лет 10 месяцев назад
Прямой ток базы (ключ открыт) определяется цепочкой резистор-диод 20....40 Ом. В этот момент ёмкость подключенная параллельно этой цепочке заряжается.
Когда положительный импульс на базе прекращается , напряжение конденсатора прикладывается плюсом к эиттеру ключа, минусом к базе.
Таким образом обеспечивается быстрое рассасывание неосновных носителей и форсированное запирание ключа.
Обратный ток базы ограничивается при этом другим резистором в базе 2...5 Ом ( иногда отсутствует ).
Электролит в данном случае является источником тока для запирания ключа и от его состояния , ёмкости и ESR зависит надёжность запирания ключа.
Высыхание и потеря ёмкости электролита ведёт к плохому и медленному запиранию ключа. Появляются свозные токи, сначала может срабатывать защита .
В худшем случае происходит взрыв ключей и выгорание базовых цепей и даже цепей раскачки.
Так что емкость лучше брать с запасом 4,7мкф с учётом на усыхание и/или шунтировать керамикой.
Aleksey_56
[OFF]Извиняюсь за вопрос не по теме, но в тему последнего обсуждения, как изменение величины сопротивления резистора в цепочке резистор-диод в базе ключа влияет на работу схемы в целом, в разных блоках со сходной схемотехникой стоят разные сопротивления (при чём разница на порядок, низкоомные предохранители не в счёт), или же данное сопротивление рассчитывается в зависимости от ттх применяемых транзисторов, на пример при замене 3DD4515 на 2SC4140 или на 13009, D209 в идеале нужно ли подбирать эти сопротивления.?[/OFF]
В идеале - нужно рассчитать. Реально - никогда не заморачивался. И так работает.
Aleksey_56
[OFF]Формула расчёта - военная тайна?[/OFF] :-)
Aleksey_56
[OFF]С какой стати вы решили , что всё что вам нужно ,а скорее всего не нужно преподнесут здесь на блюдечке ?[/OFF]
[OFF]Собственно, я ни чего и не требовал, всего лишь спросил, просто есть проблема и я пытаюсь выяснить её причины возможно она и скрыта в указанных резисторах, если вам нечего подсказать лучше воздержаться от комментариев и не разводите флейм.[/OFF]
