Автор: NMD , 10 ноября 2007
Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
17 лет 8 месяцев назад
;) два лучше чем ни одного.
Только BU508 вместо MJE13007 ставить не интересно. Максимальный ток одинаковый, а цена вдвое - втрое выше.
Mr.Woland
у нас цена практически одинакова 27 и 35 руб
508ые как то посерьёзнее выглядят мне кажется
и по напряжению повыше вроде
Igorpes
Доброго времени суток
Помогите определить что за транзистор:
1-я строка: FC0312
2-я строка: S**
3-я строка 2**0B
на месте * дырка прогорела.
Стоит в силовой дежурки.
Блок питания Poewrman , Model: HPC-360-102DF
Google, Alldatasheet и его аналоги молчат по этому поводу.
Буква F в начале это видимо логотип компании файрчайлд как я понимаю.
Нашёл нечто похожее, но с трудом вериться что этот оноH7N0312AB
это скорее всего вот это KS0312A0, но у него тип корпуса не совпадает, и кто мне скажет номинал резистора который между базой и эмиттером
Не хочется методом научного тыка подбирать
Всётаки больше склоняюсь к мысли что это какоцйто мосфет
Похоже что аналогичные БП делали ещё чаефтек и ещё какаято компания, может кому попадались с такой маркировкой в ремонт? что там в дежурке стояло?
Mazayac
Эх, лентяи!
В "Схемы БП" идите, там лежит схема на Ваш блок. И транзистор, и резистор - все в ней найдете.
Igorpes
Спасибо, вобщемто оказался прав, я ещё вчира нашёл схему где дежурка почти один в один с моей совпадала, только номиналы немного другие. Давненько я не заглядывал в раздел со схемами , там занчительный прирост с тех пор произошёл
kosTV (не проверено)
17 лет 7 месяцев назад
Здравствуйте
кто нибуть знает замену W9NK90Z
NiTr0
900В, 8А (судя по гуглю, по маркировке - вроде как 9А должен быть). Искать в прайсах сходные по маркировке (9N90 и т.д.), на некоторых фирмах есть краткое описание параметров (пример - nics.kiev.ua), по ним и ориентироваться... Ессно - после подбора аналога качнуть даташит и свериться с ним.
okha58 (не проверено)
17 лет 6 месяцев назад
Помогите чайнику!!!
В БП GEMBIRD 450 вт сгорели транзисторы.
На них надписи:
на одном - D4515,
на другом A4D1805 DFP 2N60
Что это за транзисторы как они правильно называются чтобы купить!
savely
Типа вот
http://www.china-ate.com/PDF/AUDION/D4515.pdf
http://www.utc-ic.com/spec/2N60.pdf
Heb (не проверено)
17 лет 3 месяца назад
TT2146 У меня стоит в БП 350 на высоковольтной стороне - параметры неизвестны.
