By ROMby Unknown , 17 August 2005
Hello!
Sorry I don't "speak" russian, nor can I read it. I had some lessons in school, but this is ages ago. But I managed to register anyway. :-)
My problem:
I've got a ENMIC 8KAX+Pro mainboard, made in 2001. Now I have purchased a new processor, a AMD 2200XP+ Thorton. And, guess what, it isn't recognised by the BIOS.
I've tweaked the BIOS with BIOS Patcher up to 4.23. Now it is recognised as Thoroughbred B, which isn't bad. But the CPU-Freq isn't set correctly. If I set the jumpers to automatic, the BIOS thinks of the processor as Duron Applebred 1466, with jumpers to the maximum the manual describes it's 1666 MHZ. The CPU can get up to 1800 MHz.
It should be possible to set the BIOS correctly, because the mainboard supports Thoroughbreds with 1800 MHz (2200+).
Do you have any hints, or can you enhance BIOS Patcher?
My CPU is
AXMH2200FQQ3C Z379191L30155
AIXIB0350RPMW
You can get the BIOS at:
http://www.andreas-thomsen.de/patched.bin
Best regards
Andreas
  • No HTML tags allowed.
Спасиба я несмотрил
Thanx i did not look
Anonymous (not verified)
21 years 3 months ago
I found the problem, though. My vendor sent me the wrong CPU. I got an XP Mobile instead of a Thorton. It runs quite well, but with too high voltage.
Maybe there is a way to lower the CPU core voltage insted of exchanging the CPU again.
Thank you all a lot.
Best regards
Andreas
DanZer
Almost no way, without losing CPU's or mobo's integrity. To make voltage lower - you need hardware changes. If you are not afraid of some cutting and soldering - you can do it, otherwise - you'd better change either CPU or its cooler.
PS A lot of overclocking fans are dreaming about getting a real XP-Mobile...
PPS Almost forgot - mobile CPUs on desktop boards show that they are getting 2.00V. That's just a monitoring glitch, not a real value.
Andreas -
How high is youre CPU temperature, what heatsink do you have
& cooler speed?
Can you tell us how much did you pay this CPU?
DanZer -
I only dream about Troughbread B something like this
AXDA1700DLT3C - 9783697281793 - JIUHB0309UPMW :)
ivp
DanZer -
Fuck...
Find it twice, plz... :wink:
Idle:
tom@fry:~> sensors
via686a-isa-6000
Adapter: ISA adapter
CPU core: +1.63 V (min = +1.53 V, max = +1.68 V)
AGP: +1.57 V (min = +1.42 V, max = +1.57 V)
I/O: +3.42 V (min = +3.13 V, max = +3.47 V)
+5V: +5.00 V (min = +4.51 V, max = +5.50 V)
+12V: +12.24 V (min = +10.81 V, max = +13.20 V)
CPU Fan: 932 RPM (min = 0 RPM, div = 8)
P/S Fan: 0 RPM (min = 883 RPM, div = 8)
CPU Temp: +40.7°C (high = +70°C, hyst = +65°C)
SYS Temp: +36.0°C (high = +50°C, hyst = +45°C)
Load:
tom@fry:~> sensors
via686a-isa-6000
CPU core: +1.62 V (min = +1.53 V, max = +1.68 V)
AGP: +1.56 V (min = +1.42 V, max = +1.57 V)
+5V: +4.91 V (min = +4.51 V, max = +5.50 V)
+12V: +12.37 V (min = +10.81 V, max = +13.20 V)
CPU Fan: 1704 RPM (min = 0 RPM, div = 8)
CPU Temp: +45.4°C (high = +70°C, hyst = +65°C)
SYS Temp: +36.1°C (high = +50°C, hyst = +45°C)
The cooler is an Arctic Cooling Copper Silent TC.
I've paid about Ђ64.
Now I've used BP 4.51, and the temerature is lower than before (about 46°C with no load) and drops quickly when there is no load. It's never over 46°C and 1700 rpms now. And the fan can go much faster than that. My old Athlon Thunderbird 1400C always was over 52°C and well over 2000rpm.
Best regards
Andreas
ivp -
How did you think find it twice?
Andreas -
All looks like OK whit standard temp. & volt. variations.
Did you look in bios this values, monitoring software sometimes lies.
Did you meen CPU cost 64 euro?
Every CPU is colder then Athlon Thunderbird 1400 :)
21 years 2 months ago
Hi, me again!
I've tried the /A option, but it seems, I did it wrongly.
How do I set the CPU to 13.5 right from the start?
Best regards
Andreas
Just use old bios instead of this one.
(i will be of line in next 2 weeks)
All best
