интереснайа комбинация полезных сетевых утилит онлине да еше нахаляву :
http://www.dnsstuff.com/ ---> rulez
http://www.all-nettools.com/----->ok
online virus skanners: еше халявa:
http://www.bitdefender.com/scan/licence.php
http://www.pandasoftware.com/activescan/com/activescan_principal.htm
http://www.ravantivirus.com/scan/
http://housecall.trendmicro.com/housecall/start_corp.asp
етот сканит толко 1 выбранный фаил:
http://www.kaspersky.com/scanforvirus
respect :arrow: :wink:
http://www.motherboards.org/mobot/manuals/
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-42321
пожже могу еше скинут другие коды надо разобратса tолко - они в техт фаиле на еврито-китаиском.
Добавил в ФАК...
( возможны и другие варианты, но ети одни из распространенных)
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Compaq: (F10) (do this when the cursor is in the upper right corner of the screen blinking)
Dell: - F1 or Del.
Dell: - Some require pressing reset twice
Dell: - Ctrl + Alt + Enter
DTK BIOS: (Esc)
Gateway 2000: - F1
Hewlett Packard: - F1
IBM:
Older Models - In order to get into the configuration of the IBM setup screen (CMOS) screen you need to hold down both mouse buttons during bootup.
Aptiva - Press F1
IBM PS/2: (Ctrl)(Alt)(Ins) after (Ctrl)(Alt)(Del)
IBM PS/2 with reference partition: - Press Ins during boot
Some PS/2s, such as 75 and 90: - Ctrl Alt ?
Some PS/2s when pointer at top right of screen: - Ctrl + Ins
NEC: - F2
Packard Bell: - F1 or F2
Phoenix BIOS: (F1), (F2), or (Ctrl)(Alt)(Esc)
Phoenix BIOS: - Ctrl Alt S
Phoenix BIOS: - Ctrl S
Phoenix BIOS: - Ctrl Alt Ins
Sharp Laptop 9020: - F2
Sony: (F3) while you are starting the PC, then (F2) or (F1)
Tandon computers: - Hold down the key after turning on power
Tandon: - Ctrl + Shift + Esc
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Olivetti PC Pro: - Shift Ctrl Alt + Num Pad Del
Miscellaneous PC's: - Ctrl + Esc or Ctrl and Alt and +
Zenith: - Ctrl Alt Ins
eTo более подробно как воити в ИБМ БИОС на разных моделях,
если надо могу перевести на Рaшн, но думаю те кто занимаетса компами более менее часто поимут .
Current ThinkPad Models
To Run BIOS Setup:
240 series 390 series 570 series i Series 1200 i Series 1300 i Series 1400 i Series 1500 i Series 172x A20, A21, A22, A30, A31 R30, R31, R32, S30, S31 T20, T21, T22, T23, T30 X20, X21, X22, X23, X24, X30, X31
Power on. Press F1 when the ThinkPad logo is displayed during startup.
TransNote
R40, R40e, T40
Power on. Press the blue "Access IBM" button during startup when the message "To interrupt normal startup, press the blue Access IBM button" is displayed. Then select "Start setup utility" to run the BIOS Setup Utility.
Older ThinkPad Models
To Run BIOS Setup:
300350500, 510
Press CTRL+Alt+F3 at an MS-DOS prompt. The system must be in MS- DOS mode and not in a DOS session under Windows.
310, 315310E/ED315ED
Power on. Press F2 while the ThinkPad logo is displayed during startup.
365C/CS365CD/CSD365E/ED
Press CTRL+Alt+F11 at an MS-DOS prompt. The system must be in MS-DOS mode and not in a DOS session under Windows.
365X/XD
With the unit powered off, press and hold the F1 key while powering the unit on. Continue to hold the F1 key down until Setup appears.
360, 355 series380, 385 series560 series600 series701C/CS75x series76x series770 series
With the unit powered off, press and hold the F1 key while powering the unit on. Continue to hold the F1 key down until Setup appears. On the TP 701, you can also access BIOS Setup by pressing the Fn+F1 keys atanytime.
700/C, 720/C
Power on. Press CTRL+ALT+INS when the cursor moves over to the upper-right side of the screen, right after the memory count during startup.
710T, 730T
Press and hold the suspend/resume switch while powering on the computer.
http://www.commlinx.com.au/schematics.htm
http://vincent.homeip.net/en/links/computers/
PINOUTS 4 CELLPHONES itd :
http://www.gsmserver.com/pinout/pinout.php#Siemens
http://www.technick.net/public/code/pinouts.php
CELL PHONEs SERVICE MANUALs:
http://www.boot-loader.com/
