Если лениво гуглить Со следующей строки сохранить в файл с расширением reg и даблкликнуть по нему - дальше дабл ОК REGEDIT4
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\0001] "MatchingDeviceId"=- "MasterDeviceType"=- "MasterDeviceTimingMode"=- "MasterDeviceTimingModeAllowed"=- "MasterIdDataCheckSum"=- "SlaveDeviceType"=- "SlaveDeviceTimingMode"=- "SlaveDeviceTimingModeAllowed"=- "SlaveIdDataCheckSum"=-
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\0002] "MatchingDeviceId"=- "MasterDeviceType"=- "MasterDeviceTimingMode"=- "MasterDeviceTimingModeAllowed"=- "MasterIdDataCheckSum"=- "SlaveDeviceType"=- "SlaveDeviceTimingMode"=- "SlaveDeviceTimingModeAllowed"=- "SlaveIdDataCheckSum"=-
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\0003] "MatchingDeviceId"=- "MasterDeviceType"=- "MasterDeviceTimingMode"=- "MasterDeviceTimingModeAllowed"=- "MasterIdDataCheckSum"=- "SlaveDeviceType"=- "SlaveDeviceTimingMode"=- "SlaveDeviceTimingModeAllowed"=- "SlaveIdDataCheckSum"=-
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\0004] "MatchingDeviceId"=- "MasterDeviceType"=-
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\0005] "MatchingDeviceId"=- "MasterDeviceType"=- "MasterDeviceTimingMode"=- "MasterDeviceTimingModeAllowed"=- "MasterIdDataCheckSum"=- "SlaveDeviceType"=- "SlaveDeviceTimingMode"=- "SlaveDeviceTimingModeAllowed"=- "SlaveIdDataCheckSum"=-
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\0006] "MatchingDeviceId"=- "MasterDeviceType"=- "MasterDeviceTimingMode"=- "MasterDeviceTimingModeAllowed"=- "MasterIdDataCheckSum"=- "SlaveDeviceType"=- "SlaveDeviceTimingMode"=- "SlaveDeviceTimingModeAllowed"=- "SlaveIdDataCheckSum"=-
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\0007] "MatchingDeviceId"=- "MasterDeviceType"=- "MasterDeviceTimingMode"=- "MasterDeviceTimingModeAllowed"=- "MasterIdDataCheckSum"=- "SlaveDeviceType"=- "SlaveDeviceTimingMode"=- "SlaveDeviceTimingModeAllowed"=- "SlaveIdDataCheckSum"=-
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\0008] "MatchingDeviceId"=- "MasterDeviceType"=- "MasterDeviceTimingMode"=- "MasterDeviceTimingModeAllowed"=- "MasterIdDataCheckSum"=- "SlaveDeviceType"=- "SlaveDeviceTimingMode"=- "SlaveDeviceTimingModeAllowed"=- "SlaveIdDataCheckSum"=-
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\0009] "MatchingDeviceId"=- "MasterDeviceType"=- "MasterDeviceTimingMode"=- "MasterDeviceTimingModeAllowed"=- "MasterIdDataCheckSum"=- "SlaveDeviceType"=- "SlaveDeviceTimingMode"=- "SlaveDeviceTimingModeAllowed"=- "SlaveIdDataCheckSum"=-
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\0010] "MatchingDeviceId"=- "MasterDeviceType"=- "MasterDeviceTimingMode"=- "MasterDeviceTimingModeAllowed"=- "MasterIdDataCheckSum"=- "SlaveDeviceType"=- "SlaveDeviceTimingMode"=- "SlaveDeviceTimingModeAllowed"=- "SlaveIdDataCheckSum"=-
Если лениво гуглить
REGEDIT4
"SlaveDeviceType"=-
"SlaveDeviceType"=-
"SlaveDeviceType"=-
"SlaveDeviceType"=-
"SlaveDeviceType"=-
"SlaveDeviceType"=-
"SlaveDeviceType"=-
"SlaveDeviceType"=-
"SlaveDeviceType"=-
"SlaveDeviceType"=-
