Автор: Jega , 26 сентября 2009
Standard "отвал" syndrome. After pressing one of three components it start to "live" :
1) ATI IXP460
2) ATI RADEON XPRESS 200M
3) CPU SOCKET
I tried to find what of these three is broken by pressing every one, but, whatever I press it starts. Without pressing-dead.
I don`t want to heat or change something that pratice showed that is not braking. Does someone have expirience in repair of these AMILO-s?
Root
17 лет назад
change SB460 and I think you will get working notebook - these chips are very sensitive for weather on Mars :-)
And here do not agree with the previous speaker, this machine is well made Pts isolation via USB, because they are in it almost never burn, but the north bridge periodically falls off. By the way, if you look at the post code breakpoint, then everything will fall into place.
Jega
17 лет назад
It was SB460.
After colser looking on it I saw that there is litle brown spot on white letters on it. Over it there was Wireless card that had white paper who was brown on side that goes on top of SB460.
So I have to change it. I don`t have working SB460 right now, but when I find it I will replace it and reply the result.
Thank you guys.
Root
17 лет назад
Olgert
I don't think that reason of problems with SB450/SB460 is isolation via USB... I see that SB460 chips often die with symptoms like:
- HDD/ODD makes notebook hangs or HDD/ODD isn't detected
- touchpad/keyboard doesn't work
and these symptoms often appears with 'litle brown spot on white letters on it'. More concretically - brown spot located on letter 'X' in phrase 'IXP460'
Could you proof it? Really I see not so much notebooks with well-made isolation via USB... And they are brandnames - Apple, Panasonic, IBM-Lenovo, which makes notebooks on their own design...
Jega
17 лет назад
Brown spot is on letter X
ув Root, думаю можно и по русски :-), до недавнего времени работал в сц Футжи (пока на вольные хлеба не подался) и этих машин видел оч много. Если загляните в принципиалку, то поймёте что отказ мыши и клавы связан как раз с проблемой USB. отказ IDE встречается в этом мосту много реже, но да он там тоже есть, не спорю мост говно, но эти машинки приходили и с отвалами севера в том числе. Кстати на том же асере 5100 вторая по рапространённости типовуха отвал сокета :-).
В данном случае просто сбила с толку фраза "Standard "отвал" syndrome. After pressing one of three components it start to "live" : ", думал человек умеет диагностировать отвал и отличать его от смерти моста...
Root
17 лет назад
Olgert
речь не про то. Речь про другое - как Вы связали отказ USB с 'this machine is well made Pts isolation via USB'. По-моему, одно другому совсем не мешает.
что смешно, но в некотором роде, думается мне, это отвал. Точнее не совсем так - вероятно изначально был дефект моста, затем локальное повышение температуры, что приводит к потемнению на корпусе микросхемы и внутреннему механическому повреждению. Надавливаешь - становится легче...
отказ усб оч часто происходит как раз по причине банального подключения флешки и т.п., даже нормальной рабочей, просто небольшое искрение в разъёме и мосту хана..... поэтому хорошая гальваническая развязка и т.п. оч сильно облегчают жизнь мосту...
кстати это уже получается чистый трёп не по теме, если есть желание - стучите в асю, она есть в профиле, так проще
Jega
16 лет 11 месяцев назад
Let close this subject:
After change SB460 chip with litle brown spot on letter X (in IXP460 marking), Notebook started to work as new:)
I tested him for few days and there was no problems.
I have another 3 notebooks with same problem. Some of them are turning on but with no recognition of IDE/SATA drives or not turning on at all.
All have same phisical manifestation - brown spot.
Rom
[off]
brown spot
классика...[/off]
