zixel5 Понимаю Ваше расстройство, но темы
zixel5 Понимаю Ваше расстройство, но темы плодить не стоит.
Тем более, что не читавшие первую тему, второй просто не поймут.
P.S. Если хотите, перенесу всю объединенную тему в "Ищу прошивку"
Добавлено спустя 20 минут 23 секунды:
zixel5 Кстати, может все-таки попробуете еще раз воспользоваться рецептом изх Интеловского ФАКа по BIOS recovery?
Q: How do I perform a BIOS recovery?
A: In the unlikely event that a FLASH upgrade is interrupted catastrophically, it is possible the BIOS may be left in an unusable state. Recovering from this condition requires the following steps (be sure a power supply and speaker have been attached to the board, and a floppy drive is connected as drive A):
1. Change Flash Recovery jumper to the recovery mode position.
2. Install the bootable upgrade diskette into drive A:
3. Reboot the system.
4. Because of the small amount of code available in the non-erasable boot block area, no video is available to direct the procedure. The procedure can be monitored by listening to the speaker and looking at the floppy drive LED. When the system beeps and the floppy drive LED is lit, the system is copying the recovery code into the FLASH device. As soon as the drive LED goes off, the recovery is complete.
5. Turn the system off.
6. Change the Flash Recovery jumper back to the default position.
7. Remove the upgrade floppy in drive A: and turn the system on.
NOTE: If the error message “CMOS/GPNV Checksum Bad.Press F1 to Run SETUP“ appears during boot, then press [F1] to go into the “BIOS Setup Utility“, press [F9] to load setup defaults, and then press [F10] to save and exit.
В своем первом ответе я имел ввиду именно эту процедуру.
Вот ее описание на русском
Правда в этом случае надо скачать не VA84510A.86A.0056.P20.EB.EXE, а VA84510A.86A.0056.P20.IB.EXE
